Old 03-08-2011
Dufour 27 Newb
jaybeegee is on a distinguished road
roller bearing for 30+ year old Lewmar 8 winch!
Hi! I need a replacement bearing for a 30+ year old Lewmar Winch! I did speak to Lewmar and it seems that spares for this model have long been discontinued whilst spares for the more recent Lewmar 8 do not fit perfectly!
Here are some pics of the part:
Lewmar Winch 8 - a set on Flickr
Any ideas of a source ?
thanks
Old 03-08-2011
haffiman37 is on a distinguished road
If loose needles, they may be replaced. However this is the best source for this kind of bearings (Bearincage/needlecage):
Torrington offered by Dalton Bearing Service Inc
As for measuring, you have to measure the dia of the inner shaft and the dia of the race on the outer part. Just measuring the bearing like on the pic is no help.
Old 03-08-2011
Dufour 27 Newb
many thanks for your prompt reply!
Old 03-08-2011
As I all of a sudden noticed you are located in Europe (Malta), you may even try this company in Germany:
Schaeffler Technologies (INA) | Products | Axial needle roller and cage assemblies / Axial bearing washer / Axial needle roller bearings
Old 03-08-2011
Dufour 27 Newb
great thanks - sent them both an email. Yes Germany works better for me! cheers
PS Surprised someone has even heard about Malta!!!
Old 03-09-2011
mike dryver is on a distinguished road
jaybeegee if you don't have any luck with either of them call Jon at Continental Marine 617- 719-8232 that is a boat storage/wrecking yard for abandoned boats in Quincy,Massachusetts U.S.A. they have a lot of the older winches that seem to be in fairly good shape. remember our boats only spend about 5 months in the water. good luck
Old 04-16-2011
Dufour 27 Newb
mike,
thanks.
still struggling to find the winch part.
What time zone is Jon on? Do you have an email for Continental Marine?
cheers
Old 04-17-2011
saillife is on a distinguished road
You might try these guys. I've no experience with them.
WinchSpares.com
Good luck
Brian
Old 04-17-2011
RichH's Avatar
RichH will become famous soon enough
Lewmar obviously didnt make the bearings, most manufactures use 'stock' or common supply bearings ... so they are probably available from a local 'bearing supply'. If you can get the numbers off the bearing race or outer end surface, simply 'duplicate' and/or use an 'equivalent' from a different bearing manufacturer. You may have to remove (press off) the bearing to get the ID number. Failing ID of the bearing, simply take the entire bearing to a bearing supply house for 'matching'.
Old 05-13-2011
Dufour 27 Newb
winchspares.com
WinchSpares.com
Good luck
Brian
thanks for the tip Brian - winchspares.com sorted me out! excellent service and highly recommended.
lewmar winch parts Kiltmadoc Gear & Maintenance 0 05-16-2010 06:15 PM
Winch Sizing .. Lewmar 40 = what ?? Jasper Windvane Gear & Maintenance 5 12-16-2009 06:34 PM
old lewmar winch mystery davester Gear & Maintenance 9 04-22-2009 07:45 PM
Lewmar Winch No7. No Roller bearings ?? sstrong200 Gear & Maintenance 2 07-06-2007 09:30 AM
Lewmar winch crowns tkringstad Gear & Maintenance 0 10-31-2004 02:16 PM
