Diesel Exhaust - SailNet Community
Blogs
Old 06-20-2003
nauticalrich's Avatar
nauticalrich is on a distinguished road
Diesel Exhaust
Ran my 14 universal for the first time this season. During the 1 hr ride I noticed black smoke coming out of the exhaust. It didn''t seem to come out during the run but only after it idled down.
Now at my slip there seems to be very minor smoke (white or bluish, hard to tell) but only after I rev it up a little in neutral.
Is this common for diesel engines or could it be dirty fuel over the winter.
Could it be caused by the additives I put in prior to winter lay up.
Engine runs great.
Old 06-20-2003
petercra is on a distinguished road
Diesel Exhaust
According to Nigel Calder''s book "Marine Diesel Engines," black smoke is unburned carbon particles from the fuel, blue smoke is from lubricating oil, and white smoke is either water vapor or totally unburned fuel.
Minor white smoke is generally expected, particularly if the temperature is low and/or the humidity high (thus condensing any water vapor in the exhaust).
Blue smoke could be indicative of compression or ring problems.
Black smoke is OK under certain circumstances. Think of a heavy truck starting up from a traffic light, they often spew a lot of black smoke when they start up. That indicates that the engine is "maxing out," i.e. is being fed more fuel than it can burn since it''s overloaded (governor tries to increase rpm''s by feeding the engine more fuel, but there''s not enough oxygen available to burn it all). Black smoke in the absence of an overloaded engine or obstructed airflow, according to Calder (page 74) is most likely due to poor injection. Obstructed airflow can be due to excessive back pressure -- I had an obstructed exhaust which caused black smoke with my engine.
Depending on how heavy the smoke is you might want to have a mechanic look at.
Old 06-21-2003
camaraderie's Avatar
moderate?
Diesel Exhaust
Good advice on the smoke...just a small addition...the black smoke could be caused by obstructed airflow due to a dirty air filter...happened to me! Best...GB
slight oil slick in diesel engine exhaust mcagney Gear & Maintenance 5 04-15-2010 12:54 PM
fuel consumption gas vs diesel jklewissf Gear & Maintenance 19 09-12-2009 10:01 PM
Diesel Deckplate ERUPTION pma_foyl General Discussion (sailing related) 1 07-06-2004 08:16 AM
diesel tachometer diesel MHRitter Gear & Maintenance 1 09-17-2002 12:52 PM
Atomic 4 exhaust dlahlers Gear & Maintenance 1 10-18-2001 02:18 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
