Heat and hot water - Page 2 - SailNet Community
 2Likes
post #11 of 17 Old 03-13-2011 Thread Starter
Thanks, let me know how it works out. My install is not imminent, but I'll post what I do.
WanderingStar is offline
post #12 of 17 Old 03-13-2011
Bathurst NB
PeterSailer's Avatar
If you're short on money you could just buy or build a small wood/charcoal stove.
Very simple and you could heat your water on a pot or you could make a systeme where a copper pipe goes around the stove several time so it heats your water.
This solution is cheap and simple ( just the way I like it )
I hate storms, but calms undermine my spirits." - Bernard
PeterSailer is offline
post #13 of 17 Old 03-13-2011
"Sparkie"
j34035's Avatar
Check this months issue of Good Old boat. There is an article about installing a used heater in a sailboat.
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
post #14 of 17 Old 03-14-2011 Thread Starter
Thanks again, I'll look for GOB.
I've considered solid fuel heat, and like the idea. I think it might be simpler to build a stack for my gas oven and use that. But the wife still wants running hot water, and I do have space in the engine room, and she carries plenty of diesel.
post #15 of 17 Old 06-14-2013
Thumbs up Re: Heat and hot water
I installed forced air diesel furnace Planar last October in my 42 ft. motor boat. Had no problem to stay on board during a winter season. It's not crazy cold here in BC but chilly and wet. The heater worked great. At one-third the cost of the equal Webasto or Espar the furnace produces tons of heat. I can say it's a really good alternative to the existing pricey brand names.
vladru is offline
post #16 of 17 Old 06-14-2013
mitiempo's Avatar
Until you need parts or service anyway!
Jgbrown likes this.
Brian
mitiempo is offline
post #17 of 17 Old 06-14-2013
Brian be less conservative.
It doesn't take a lot to replace a glow plug. And the parts are always available from the Planar dealer in Vancouver. Also the heaters come with 2-year warranty provided by the dealer and backed-up by manufecturer.
vladru is offline
water heater heat exchange program Skipper Joe Gear & Maintenance 4 05-31-2009 06:27 PM
Dickinson Stove to heat Hot Water Tank ncapener Gear & Maintenance 6 04-06-2009 12:14 PM
Water Heater heat exchanger hook up question EO32 Gear & Maintenance 36 08-25-2008 09:06 AM
The heat of the sun... merlin2375 Gear & Maintenance 20 06-09-2008 11:38 AM
Using Heat Bro Gear & Maintenance 2 11-13-2002 04:26 PM
