Old 03-14-2011
DrB DrB is offline
DrB is on a distinguished road
Thru-Hull Install
I am replacing my engine cooling intake grate/thru-hull from a 1/2" to a 3/4" grate.
The 1/2" threaded grate has only one flange mounting hole in the back where a long thing bronze screw secures it from not spinning. It is also where I put a grounding wire to it. Basically the threaded portion is the primary mean of securing it to the hull.
The 3/4" grate has 2 or 4 mounting holes, plus the threaded section, to secure to the hull. The plan was to use this in conjuction with true seacock or a thread it into a seacock flange and then put a ball valve, with the correct thread, on top of the flange.
The issue is that the flange has three mounting holes, GROCO FULL FLOW BALL-TYPE SEACOCK, and the thru hole strainer 2 to 4 mounting holes. I am concerned that if use all the holes, the seacock flange will cover the thru-hull and vise versa. I am also adverse to drilling a bunch of hole in the bottom of the boat for screws.
Ideas?
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
Old 03-14-2011
tommays's Avatar
Seacock Backing Plates / Alternate Method / No Through Bolts Photo Gallery by Compass Marine at pbase.com
I went with Mainsails no bolt when i replaced mine and it has worked out very well
I dont really care for the external strainers and find the internal one works well and i can see and clean any junk
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 03-14-2011
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
The through hull area is likely a breeding ground for barnacles, and the strainer provides them with shelter so that they cannot be removed.
Also, in the possibility that you suck a piece of plastic or weed through the strainer which blocks the through hull itself, the strainer prevents you from clearing the through hull.
Loose it!
Old 03-14-2011
Maine Sail's Avatar
Feel free to read this..
Why I Dislike External Strainers
______
-Maine Sail / CS-36T
Old 03-14-2011
tommays's Avatar
The hardest part is figuring out how thick to make you filler
Tommays
Northport NY
Tacktick thru hull install ambianceack Gear & Maintenance 6 12-09-2010 05:10 AM
Multi-Hull vs Mono-Hull Sailboats? terryjoe Boat Review and Purchase Forum 8 11-11-2007 10:45 AM
Do you paint over thru hull bronze nipples on hull saurav16 Gear & Maintenance 4 08-19-2007 06:15 PM
C400 Batt install and Inv/CHg install Cruisingdad Catalina 1 08-01-2007 01:02 PM
Sonar, and where to install... Everlong Gear & Maintenance 2 05-26-2007 09:10 PM
