Old 03-14-2011
sophist is on a distinguished road
cape dory mail sail
I am looking to replace the main sail for my cape dory typhoon weekender. I have price quotes and sail weights all over the map.
Questions
What was the orignal sail weight?
What weight should the new sail be- don't race but daysail only off coast of MA?
Should I reduce the P measurement slightly to raise the boom when sailing.
Thanks
Sophist
  #2
Old 03-14-2011
LessTacksing is on a distinguished road
Send a message via Skype™ to LessTacksing
Why don't you try the cape Dory owner's association at capedory.org. They may have mor info for you.
  #3
Old 03-14-2011
RichH's Avatar
RichH will become famous soon enough
A 5 oz. 'quality' woven dacron would be appropriate for a 'weekender' on the coast of MA.
For your 'too low boom' .... perhaps you're not properly raising your present mainsail properly. This is VERY common problem that results in a boom that apparently is too low. Suggest you go to: How to properly RAISE a woven dacron mainsail - SailboatOwners.com and follow the directions to evaluate IF in fact youre not raising your present sail correctly .... and if these methods correct the 'sagging boom' then there will be no need to alter the sail plan dimension. Plus if you follow that 'posting' you may not even need a new mainsail, just a simple alteration to restore the shape, etc.
If you already are properly raising the sail (so that the 'clearance under the boom is proper'), a few % cut from the foot so that you can raise the boom will not appreciably alter the boats sailing characteristics .... and may even be a plus in the mid-afternoon 'sea breezes' when a 'slightly smaller' main would be of benefit.
For your specific 'windy' afternoon sailing venue, suggest you actually discuss these 'special' requirements face to face with a sailmaker .... perhaps a 'flatter cut' sail, and/or a sail cut with reduced 'shoulder' or 'twist' in the upper panels etc. to better handle the late afternoon 'roar' along the NE coast would be of benefit. Youre not going to get this from a 'mail-order' sail maker.
You may post attachments
You may edit your posts
Cape Dory 28 Cape Horn Self-Steering Installed BillOfCapeCod Gear & Maintenance 6 05-20-2009 07:49 PM
Cape Dory 25 Gryzio Boat Review and Purchase Forum 12 01-19-2008 05:54 PM
Is a 18' Cape Dory Typhoon really that hard to sail? bradlawson Learning to Sail 8 08-30-2007 09:12 PM
Cape Dory 30 DirtManly Boat Review and Purchase Forum 15 03-31-2004 08:06 AM
Cape Dory 30 halyardz Boat Review and Purchase Forum 0 06-27-2002 10:41 PM
SEO by vBSEO 3.6.1
