Old 03-15-2011
chrisncate's Avatar
Mango intolerant
chrisncate is on a distinguished road
Benefits/drawbacks of aluminum pushpit/pulpit as opposed to SS.. ?
I am wondering about switching from SS to aluminum in order to shave some weight where I can.
Old 03-15-2011
scottyt is on a distinguished road
well it would work, but you need to over build it for strength. then you lose some of the weight savings. honestly it might save you 10 lbs, not worth it in my mind.
Old 03-15-2011
chrisncate's Avatar
Mango intolerant
So not much weight savings then... aluminum sure seems a lot lighter though..
Old 03-15-2011
In order to have the same stiffness and support as Scotty said it would need to be thicker walled and so the savings would be minimal.
Also for appearance's sake it would need to be anodized to prevent surface oxidation that would make it look like a work boat fitting - so cost savings would likely disappear too.....
We have anodized aluminum stanchions on our boat and even they tend to need more regular cleaning than the SS rails fore and aft.
1984 Fast/Nicholson 345
Old 03-15-2011
mitiempo's Avatar
As well stainless will bend in the case of a rail where an aluminum one will often rupture.
Brian
Old 03-15-2011
chrisncate's Avatar
Mango intolerant
Sounds like aluminum is a bad idea. I figured I'd ask though...
Old 03-16-2011
Minnewaska will become famous soon enough
Before I ever start to worry about modification just for the sake of saving 5 or 10 pounds, I would just go on a diet. Cheaper and I could do even better, if I set my mind to it.
Jeanneau 54DS
Old 03-16-2011
catamount's Avatar
catamount is on a distinguished road
If you're trying to save weight, besides putting yourself on a diet -- put the boat on a diet. Remove everything from the boat. I mean everything!
OK, now that you've removed everything that's not bolted down, you can start working on the stuff that is bolted down. For example, can you move batteries from an aft locker to a more central location?
(BTW, while you've got everything out, this would be a good time to thoroughly vacuum and wash the entire interior of the boat.)
When you're putting stuff back on, be very thoughtful about what you put on and where you put it. There's probably a lot of stuff that you just don't really need. This is the time to re-organize your stowage arrangements.
You are right to think about getting weight out of the stern -- in my experience Alberg designs tend to squat.
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
Old 03-16-2011
NCC320 is on a distinguished road
Why are you trying to save weight? For example, look at the weight difference of the aluminum vs. ss pushpit. That difference would be exactly what percentage of the boat's total weight? If you wanted a light boat, you should have started with a different design. "Blue water" boats, or at least what most people consider and want as blue water are those heavy overbuilt boats that will take any abuse. Being heavy and light at the same time seems a little inconsistent. In my opinion, we boaters waste lots of money by paying for high tech, low weight, overpriced components that really have no impact on the boat or it's performance. Sounds good, I guess, to know you have super light lines, or blocks, or aluminum (titanium is better still) components.
Old 03-16-2011
catamount's Avatar
Every little bit counts -- it all adds up. Don't forget to cut your toothbrush handle short, and drill a bunch of holes thru what is left.
OK, I'm being sarcastic, but any reasonable boat, no matter the design, can benefit from thoughtful consideration of what weight to put on (or not) and where to put it.
Echo Charge drawbacks? myster Gear & Maintenance 10 10-13-2008 10:24 PM
Pushpit Materials Bermuda30 Sailboat Design and Construction 1 07-21-2008 01:38 PM
Cal 25 Pushpit?? sturmkatze Cal 0 10-17-2007 05:37 PM
Used Boats as opposed to New bayouelton Boat Review and Purchase Forum 1 09-11-2006 10:23 PM
Replacment Pushpit Tree Gear & Maintenance 4 02-06-2005 05:58 PM
