03-18-2011
First, be aware that bleach is highly corrosive in an aluminum tank so you may solve your problem sooner than later by having to replace the tank.
Second, boats sink from city water hook-ups. Most boat plumbing cannot handle the pressure so you at least need something to reduce the pressure. If you spring a leak in you plumbing and your bilge pump cannot handle it, your boat will fill up and that will not be good.
We live aboard and have FG tanks built into the boat. They are very clean but we still run through a filter and use a PUR filter pitcher for drinking water. We fill up our tanks(165 gal) every few weeks.
You can use bleach to shock your tanks but you need to clean the bleach out afterwards with lots of fresh water. You can then use a vinegar mixture to get rid of the bleach taste/smell. You might also consider cutting clean-out ports in your tanks so you can easily clean them. Leaving water in a tank is not good. If you are not using them, leave them empty. The algae is likely from leaving the tanks partially filled for long periods.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
