03-19-2011
Wire conduits are usually situated at 2/4/7/10 "oclock" on the mast section. Mast steps are typically centered up the sides of the section, and in-line with the spreaders meaning your conduit will not have a straight shot. Too bad, because doubling up the fasteners' function makes sense otherwise.
btw our mast has an extruded section behind the sail track that takes a sliding plate, creating a continuous cavity for wires.. clever idea (Selden)
Often you'll see a row of rivets in a mast either side of center that is holding the conduit in place.
Get ahold of some plastic tube/pipe and see if you can push that past the spreader location.. you'll find a path (and likely the right spot for the conduit) that way.
Remember, too, that if you're adding/using a steaming/deck light fixture the wires for that will need to exit the conduit at that point.
Fun, huh??
1984 Fast/Nicholson 345
