Carpet in the cabin - SailNet Community
post #1 of 15 Old 06-23-2003 Thread Starter
Carpet in the cabin
We just bought a 1976 Catalina 22. We''re thinking of installing marine carpeting in the cabin. Has anybody here done this to theirs? Did you just carpet the deck, or did you carpet the vertical surfaces and sitting/sleeping surfaces? If you carpetted the vertical and sitting surfaces, how did you butt the seams together and prevent the seams from fraying?
wintermute11 is offline
post #2 of 15 Old 06-26-2003
Carpet in the cabin
Just the sole and we cut to fit; it was a difficult job. The edges are bound with stichted binding tape. It is holding up well and the carpet surface is good for non-skid and protection of the teak.
ammcguire is offline
post #3 of 15 Old 06-26-2003
Senior Nappy Headed Ho
Carpet in the cabin
Carpet is for living rooms, put a teak and holly cabin sole in your boat. It''s easier to clean, better non skid and will not mildew.
Denr is offline
post #4 of 15 Old 06-26-2003
pirateofcapeann's Avatar
Carpet in the cabin
I fitted a piece of interior/exterior industrial grade carpeting to the inside of my C22. It was a remnant that was getting tossed out after a job at the company I was working for, so it didn''t cost me a dime. It being exterior grade, it was made from synthetic materials and as such, was easy to cut and burnish the edges with a soldering gun and a knife attachment.
As for the results, it seemed to deaden the "tinny" sound of the fiberglass cabin and it seemed to insulate the cabin sole a bit from the cold. This was a good thing when getting out of the bunk on a cold morning. I had cut it in well enough that it didn''t seem to wonder or slide about even under the worst conditions. It gave a nice "homey" atmosphere to the boat and drying it was simply a matter of lifting it up and tossing it into the cockpit. It held up well, two years that I had it in there and it went with the boat when I sold her.
pirateofcapeann is offline
post #5 of 15 Old 01-15-2009
CLucas's Avatar
Send a message via AIM to CLucas
I would suggest purchasing either an inexpensive runner (with a non-skid mat underneath) or a decent bath mat with a rubberized back -- the latter can be tossed into the washing machine and is easily replaced if it gets badly soiled.
Oh yeah... and you don't have to varnish it
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
CLucas is offline
post #6 of 15 Old 01-15-2009
bljones's Avatar
CLucas, good advice. BTW, did you know the thread you are replying to is over five years old?
bljones is offline
post #7 of 15 Old 01-15-2009
CLucas's Avatar
My bad... Presumably the OP has found a solution by now. Thought I saw this listed as a 'New Post' while eating my lunch -- apparently not (mistake likely due to my brain being near frozen solid with this weather).
s/v Grey Goose
~~~~~~_/) ~~~~~~
CLucas is offline
post #8 of 15 Old 01-15-2009
bljones's Avatar
No problem. Good advice is never a bad thing, timely or not. I figured i'd bring it to your attention before SD did.
bljones is offline
post #9 of 15 Old 01-15-2009
CLucas—
Occasionally, an old thread will get listed as a "New Post" because some spammer has posted to it, and then their post gets nuked, but the thread still gets listed as having recent activity.
sailingdog is offline
post #10 of 15 Old 01-15-2009
montenido's Avatar
CLucas, old or not, your advice is appreciated. I just had to post because SoCal is in the middle of a heat wave. Santa Ana winds and temps in the high 80s and low 90s.
Sorry, I couldn't help myself. Thanks for the advice.
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
montenido is offline
Cabin Cooling Radiators flicker Gear & Maintenance 3 11-21-2003 07:43 AM
Open Cabin -- August BVI Charter Kathie_WE Chartering 0 06-15-2003 05:08 PM
leaky cabin windows asailor Gear & Maintenance 2 10-21-2002 03:40 PM
cabin top repair grnich24 Gear & Maintenance 1 04-20-2002 06:23 PM
c&c 40 aft cabin ? patr Boat Review and Purchase Forum 0 07-23-2001 02:04 PM
