Bottom paint: Micron Extra/CSC, Pettit Ultima SR-40/SR-60 - Page 5 - SailNet Community
 3Likes
post #41 of 58 Old 01-09-2013 Thread Starter
Panhandle Sailor
dreuge's Avatar
Re: Bottom paint: Micron Extra/CSC, Pettit Ultima SR-40/SR-60
UPDATE
I went with the Petit Ultima SR-60. Since then, my boat has been in the water for 1-1/4 years, and the bottom still looks newly painted! I have had a little bit of green slim and have gently wiped down the bottom two times over the last year.
In an area where barnacles and oysters are a big problem, I have no, zero, zilch problems from to these critters. I am hoping to go three years before hauling out again. So far so good.
Originally Posted by dreuge View Post
I am looking to repaint the bottom of my sailboat. It is going on three years since it was done by the previous owner. The paint currently is/was an ablative paint.
I sail in the gulf along the FL panhandle, and I am planning on going with another ablative paint. Barnacles are problem here. So far I have narrowed my choices down to 4 paints. I was originally planing on going with an Interlux, but I recently came across the Pettit Ultima paints which currently have rebate offers ($10-$20/gal off).
I would greatly appreciate any input on the 4 paints listed below. I am leaning towards the SR-60 or the Micron Extra(SR-60 with rebate is $40 less per gallon). For a C&C 29 mk1, I expect I'll need two gallons. Has anyone had good success with the SR-60? I searched the Sailnet forums on SR-60 and found no hits, so I guess it is rather new product.
[1] Pettit Unltima SR-60
[2] Interlux Micron Extra
[3] Pettit Unltima SR-40
[4] Interlux Micron CSC
T37Chef likes this.
S/V Johanna Rose
dreuge is offline
post #42 of 58 Old 01-09-2013
T37Chef's Avatar
I would agree with the TrinidAd SR if I was to go "hard"
That just doesnt read well
Shawn
T37Chef is offline
post #43 of 58 Old 01-09-2013
chef2sail's Avatar
Its how old guys speak
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #44 of 58 Old 01-09-2013
Old as Dirt!
svHyLyte's Avatar
UPDATE
We have been using the Petit Ultima SR in the south Tampa Bay area for quite some time and have found that even after 2-1/2 years, the paint remains very effective. FWIW we have the bottom wiped down once a month or so by our diver.
svHyLyte is offline
post #45 of 58 Old 01-09-2013
chef2sail's Avatar
Rick,
We use Ultima 60 in an environment which has salinity and fresh water also. Since you are on the Delaware is there no salt water where you are? Hard to beleive in the summer when the salt line comes up the Delaware it doesnt reach Essington. So its entirely fresh water where you are? I would have though you had some salt content to it.
Dave
Parkville, Maryland
Our blog-
post #46 of 58 Old 01-09-2013
As you get older, hard bottom paint is as exciting as it gets.
chef2sail likes this.
MarkSF is offline
post #47 of 58 Old 01-09-2013
T37Chef's Avatar
Bawahahahahaha
Shawn
T37Chef is offline
post #48 of 58 Old 04-23-2013
Has anyone applied Pettit Ultima SR-60 hot-coated over Interprotect 2000? I had my bottom peeled and a new vinylester layup applied. My fiberglass guy is recommending Interprotect and I want to use the Pettit Ultima SR-60 over that. Interlux says that hot coating (thumb print test) with Ultima SR-60 is ok. Here's the thing: the instructions for Pettit's version of epoxy barrier coat has instruction for hot coating with bottom paint that sound similar to Interlux's, except for the SR-60. For SR-60, the barrier coat should be set up to "Tack free". SR-60 uses a different solvent than SR-40 and the other paints, so I'm wondering if that is why the difference. Anyway, I know at least someone had put SR-40 over Interprotect, I was wondering if anyone has had success or problems with hotcoating Interprotect with the SR-60.
SaltyHog is offline
post #49 of 58 Old 04-23-2013
4arch's Avatar
Salty,
I used 2 coats of SR-60 over 2000e last month and "hot coated" the first coat of SR-60. I didn't have any issues. The boat's back in the water now though, so if any long-term issues come up, I won't know for a while.
I'd be curious to check out the literature you were looking at if you have a link? I found Pettit's TB-Z155 Bottom Painting Bare Fiberglass technical bulletin advised applying SR-60 to their 6999 Sandless Primer tack-free. But as far as I can tell, the 6999 is not an epoxy product. Their 4700/4701 looks to be a 2-part epoxy barrier coat more similar to the 2000e. I couldn't find any info specific to SR-60 over the 4700/4701.
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is offline
post #50 of 58 Old 04-23-2013
Maine Sail's Avatar
I used Horizons as the "hot coat" layer at the advice of Pettit. Horizons is the same base co-polymer paint without the slime blocker and a little less copper (equal to Ultima SR40). They suggested the non-slime blocker as the hot coat/tracer then you can switch to Ultima SR. This went over IP2KE 6 years ago and there are zero adhesion or build up issues. Steve Miller our local rep up here has recently told me that hot coating with either SR40 or SR60 is not a problem at least with their barrier coat. He would not comment on IP2KE which is what I used.
Keep in mind that as copper content goes up, and slime blockers get added, coverage per gallon goes down slightly. SR60 covers about 400 sq ft. and Horizons covers about 500 sq ft., SR 40 about 450 sq ft. SR60 has a different solvent than SR40..
Just finished applying SR60 and it is tough to cover my hull with 1 gal but I can easily do it with SR40. SR40 is the exact same paint as West Marine PCA GOLD...
______
-Maine Sail / CS-36T
Maine Sail is offline
Pettit Ultima SR40 Report - Chesapeake Bay T37Chef Gear & Maintenance 0 09-26-2010 08:48 PM
Anyone need a gallon of Micron Extra with Biolux - Blue? Bene505 Gear & Maintenance 2 05-06-2010 09:49 AM
Touching Up Chipped Ablative Paint (Micron CSC) pdo333 SailNet FAQ 3 04-27-2010 01:27 PM
Micron Extra vs. Micron CSC vs. Petit ??? CLucas Gear & Maintenance 18 03-28-2010 07:23 PM
Pettit Ablative Bottom Paint Joel73 Gear & Maintenance 1 02-24-2009 05:39 PM
