03-22-2011
Tohatsu 6: How fix steering position?
I have a Tohatsu 6 Sail Pro (extra long shaft) to which I added the remote control box and cables, so that now I adjust shift and throttle with a single lever in the cockpit, rather than using the throttle control arm and shift lever on the engine.
Sadly, because of normal vibration, the motor keeps working its way out of position. I can't keep it pointing dead ahead. There is an adjustment screw in the rear of the drive shaft enclosure. I thought the screw was there to lock the motor in place -- but then I read in the user manual that the adjustment screw is meant to adjust only "the friction load of the steering, but not to fix the steering."
The manual also says that "excess tightening of the adjustment screw may cause damage to the swivel bracket."
Before I read that, I had adjusted the screw pretty tight several times and it never stopped the motor from slipping and turning left or right.
So, since I can't use the friction screw to lock the motor in position, pointing dead ahead -- how can I do it?
Thanks.
