03-23-2011
The filler is a product to make epoxy into a fairing compound. Unless you introduce fibers into the mix, the structure will lack tensile strength and flexibility. If you need a load bearing structural member, laminate it with cloth. If you need more stiffness, you will need quite a few layers. If you increase the thickness by using a core material, you can get away with a lot less. Epoxy itself is only an adhesive and filler. The strength comes from the glass fibers.
So, in short, my opinion is that either fully laminate it or use a core.
