Originally Posted by tdw
Ilenart, Hi.
I'm a bit confused by this as well. Is it that the chain doesn't run through the pipe cleanly or is is that the pile of chain builds up and blocks the pipe?
If the former then increasing the slope of the pipe should help but you then run the risk of the pile of chain building up and blocking the outlet.
On Raven we have the problem where the chain piles up under the windlass until it jams in the pipe. Have to kick it away every now and then which makes pulling up the anchor something of a pain but doable.
If it is in the pipe, Capecodda's idea sounds good .
The chain does not run through the pipe cleanly, I think where there is a bend in the pipe. Hence by making the drop steeper (either by shortning or lowering the pipe) this may clear the blockage.
Another alternative is to make the bend larger or less sharp. However, as the bend is built into the bulkhead, this will require major surgery in an area which is painful to get at. Hence I am looking at other options to try first.
There is actually a fair bit of room below the pipe at the moment (yep the picture does not really highlight this). So I'll probably try lowering the pipe first. If I hit problems with the chain building up and blocking the pipe, I'll then cut back some of the pipe.
Also this is a rope / chain combination and I think the chain is sitting on some of the rope. As the rope has to done by hand I can probably pull that further back out of the way and the chain will have even more depth to fall into.
svHyLyte, thanks for the idea of an idler wheel, have'nt heard of that one before.
Thanks for the other comments. Once I figure this one out I'll post whatever I come up with.
Ilenart
PS another thought, could just get the ol' ball & chain to pull it through, however that does not work when you are singlehanding
