Installing aluminium mast steps on steel mast - Page 2 - SailNet Community
post #11 of 11 Old 01-29-2012
billyruffn's Avatar
You can isolate the AL from the steel using small pieces of 1/8” nylon sheet between the pad on the step and the mast. (source: McMaster-Carr). Then use SS screws with threads and heads coated with Tuff-gel or similar thread protector. It’s the same technique I use in mounting winches on an AL mast.
(Edit: Just realized this is an old post....but I’ll leave the comment up anyway.)
billyruffn is offline
Mast steps Atkinsericjr808 Gear & Maintenance 2 08-22-2010 09:27 PM
Mast Steps tdw Gear & Maintenance 34 07-31-2008 10:42 PM
mast steps mokiemike Gear & Maintenance 1 11-13-2007 12:48 PM
ABI Mast Steps waltzingmatilda Gear & Maintenance 24 09-18-2007 09:44 PM
mast steps egregerson General Discussion (sailing related) 1 08-21-2006 01:04 PM
