Old 03-26-2011
Perithead's Avatar
Montgomery 17
Perithead is on a distinguished road
Question about small blisters
I just purchased a Montgomery 17 knowing that the bottom was 75% covered with blisters no larger than 1/8" in diameter and they are raised from the surface probably about the thickness of a sheet of writing paper or maybe a grunt more. I got a great deal on the boat so I am prepared to fix them if it is needed. The boat had been sitting in the water for 2 years, but it has been on the trailer now for probably 2 months or more.
I just got the boat home today and the first thing I did was take my key and try to burst open a few of the blisters to see how bad they were. When I would press on a blister with my key I would hear a very small cracking sound but I could not physically see any cracking being done and I could not see the blister "caving in". Also, no moisture was visibly present. I even scraped them a bit with my key trying to break them open but I couldn't get anything to come off.
My question is are these bad enough to need repairing? Cosmetically I do not mind the blisters at all, all I am really concerned about is the bottom paint adhering to them and not coming off.
I plan to paint the bottom with Pettit Vivid aintfouling bottom paint. If I didn't repair the blisters I would just scuff up the bottom with a sander then apply my paint.
So should I just paint it or fix them first? I am thinking just paint......
Small is beautiful, simple, cheap, and easy......
Visit my website
! Lots of useful info and sailing videos.
Old 03-26-2011
mitiempo's Avatar
I don't think they are a big problem. Here's a link that explains gelcoat blisters very well. Sea Lake Yacht Sales (Kemah, TX)
Brian
Old 03-26-2011
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
Have a look at this http://www.cncphotoalbum.com/doityou...oat_repair.htm
I repaired some small clusters of blisters 6 years ago by poping them with a drill, washing and drying them out over the winter under cover and filling with International 2 part epoxy. Last years survey give me a clean report.
Yours are more wide spread so maybe leaveing them alone or stripping the whole gelcoat are the choiceses.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
Old 03-26-2011
brokesailor's Avatar
SV Skalliwag #141
brokesailor is on a distinguished road
Wow those two articles contradict each other!
Old 03-26-2011
Perithead's Avatar
Montgomery 17
Well, I guess I'll slap a coat of paint on the bottom and se what happens. If it fails, I am only out enough paint to paint the bottom on a 17' boat, not much....
Visit my website
Old 03-26-2011
Minnewaska will become famous soon enough
When faced with contradicting professional advice, I usually pick the one where I can afford to be wrong.
Jeanneau 54DS
Old 03-26-2011
mitiempo's Avatar
Blisters in the gelcoat and only the gelcoat are not a big problem, only cosmetic. If the blisters are in the laminate they are a problem. Blisters rarely go past the gelcoat. The article I linked to is by a very experienced surveyor. I have no idea where the second article came from as it is not even credited.
Brian
Old 03-26-2011
Ops, the article came off the C&C website.
C&C Yachts - C&C Photo Album & Resource Center
Of course its just an article, but does concur with a lot of the info I gathered before deciding what to do about my own hull blisters.
Safe sailing
Old 03-26-2011
mitiempo's Avatar
There is an entire industry stripping off gelcoat and repairing the dreaded "osmosis". There are very expensive tools made and sold specifically for this. Fear is good for this as well as many industries.
Jan de Groot, a surveyor with decades of experience going back to the days before fiberglass has never seen gelcoat blisters progress past the mat layer just under the gelcoat and into the structural roving of a hull, nor one damaged in such a way as to be unsafe or unusable.
There have been issues such as the fire retardant resins used by Uniflite/Valiant referred to in the article (but not named) and that was a unique situation due to the additive used to make the resin fireproof. This problem was deeper than the gelcoat and existed throughout the laminate. Since fixed by the builder.
And the rare case of blistering that does go through the laminate because of contaminated fiberglass cloth/roving.
I have personally heard of many cases of blisters but none past the mat layer and into the structure. If there are a few, pop them, dry them, grind to get to the laminate but not past it and epoxy fill them, paint and you are good to go. If they are covering the whole hull removing the gelcoat and the mat below it is the answer to a good finish.
But don't live in fear of the hull falling apart because it just doesn't happen.
Brian
Old 03-26-2011
The question posed So should I just paint it or fix them first? I am thinking just paint...... didn,t give me the impression Perithead was living in fear.
Safe sailing
Small blister question GenesisCaptain Gear & Maintenance 7 04-12-2010 09:28 PM
Small engine question Fstbttms Gear & Maintenance 35 01-18-2009 08:35 PM
The question of Blisters yet again? mvsunstar Boat Review and Purchase Forum 23 02-03-2007 10:29 AM
a small question rmbjspd Boat Review and Purchase Forum 16 08-09-2006 06:03 AM
small blisters jharrison Gear & Maintenance 2 01-24-2002 10:16 AM
