Old 03-26-2011
xluke is on a distinguished road
Sink Water pump
Hello,
My new-used boat has a manual water pump on the sink that is not working. The one in the bathroom does work so the tank is OK. Can anyone provide me with basic suggestions as to why these fail? It feels like it has some action but is not producing any water.
Thanks!
Old 03-26-2011
Minnewaska will become famous soon enough
Internal o-rings, gaskets, etc could have worn and no longer create a vacuum. Also, be sure there isn't a valve along the way that may be closed to insure a leak enroute didn't empty your fresh water supply. There is often a valve that allows you to switch between fresh and seawater, as well. That may be stuck between the two or set to seawater and there is a block. Just random thoughts.
Jeanneau 54DS
Old 03-26-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Originally Posted by xluke View Post
Hello,
Thanks!
Hand Pump? Foot Pump?
Raw water for galley sink okapi3 Pacific Seacraft 13 05-05-2010 09:56 AM
Need water pump? saltypat Gear & Maintenance 1 05-29-2009 02:08 PM
Bilge Pump Exit - Why Not Use Sink Drain? montenido Gear & Maintenance 11 01-06-2009 12:16 AM
Raw water pump bestfriend Gear & Maintenance 56 04-26-2007 09:03 AM
SEAFARER 22 - Sink/Water System MZDANOW Gear & Maintenance 10 02-28-2007 11:05 AM
