Old 03-26-2011
xluke is on a distinguished road
Outboard as a saildrive -- basics, curious.
Hello,
I recently got a new-used sailboat that has an OMC saildrive. She runs like a champ but I have never seen a saildrive unit before and am generally curious about them. They seem to be essentially an outboard. Could an outboard be used to replace a saildrive? I.e., could one create a wood/fiberglass mount (i.e. wood for structure, fiberglass to protect) all around an outboard and then drop that into where the saildrive was (thus having the lower end underwater and the upper end in the engine well) with a little glassing to keep her sealed up? If not, why? What is the difference?
Thanks!
Old 03-26-2011
trantor12020's Avatar
trantor12020 is on a distinguished road
Yes you can. There are production sailboat that uses OBM this way. The Platu has an OBM well in its cockpit. You could haul out the obm when sailing. Just note that if the obm well covers it too air tight the engine won't get enough air for running.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 03-26-2011
haffiman37 is on a distinguished road
OMC, made this many years ago mainly based on the 25HP power head. The specific saildrive parts are a bit difficult to source, but not impossible. Even Volvo Penta made a similar one back in the late 70's based on the then Honda 7,5 HP outboard and lower unit (internal parts) from the Archimedes Penta outboard!
There are a few boats that have outboard wells from factory, but not too successful. The engines have a tendency of running on their own exhaust, they need an 'exhaust relief' above water due to back-pressure, unless you have the hatch/cover open. Corrosion and marine growth are even problems.
Old 03-26-2011
Minnewaska will become famous soon enough
Congrats on the new boat, what year is it? I have a suspicion that your saildrive dates from the era when they were fairly problematic and those parts can be harder to find now. If it's your first, research all the preventative maintenance you can find and stay on top of it. Anodes in particular.
Jeanneau 54DS
curious merc2dogs Cruising and Sailing with Children 0 03-27-2010 11:42 AM
J40 curious scenario... ksanders Boat Review and Purchase Forum 0 03-16-2010 02:53 PM
I only ask 'cos I'm curious Mipcar Off Topic 7 06-07-2009 07:58 PM
Converting Saildrive to Outboard-any advice? windseaker Gear & Maintenance 8 03-20-2009 01:54 AM
I'm Curious .... PBzeer Off Topic 14 10-30-2007 09:59 PM
