Transom fender - Page 2 - SailNet Community
post #11 of 13 Old 03-27-2011
southshoreS24's Avatar
i was going to suggest something like the bumper guards you see on cars in urban areas. but that seems like one already made for a boat.
NYC Parking Garages - Bumper Protection, Bumper Protectors, Rear Bumper Guards
southshoreS24 is offline
post #12 of 13 Old 03-27-2011
chef2sail's Avatar
Make two detachable 1 inch webstraps which can be connected on one end with plactic snap or to an eye hook at the far end of each side of the steps at the bottom of the transome after the bottom step, clip the the other end of the webstap to your stern rails. Pull them taunt with adjustable slides. Your dinghy bottom will be guided to the water instead of the scoop. When the dinghy is stowed. simply detach and store in lazzarette. Will take two minuytes to set up when lowering dingy and since you have those nice steps...easy to do also
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #13 of 13 Old 03-28-2011 Thread Starter
Izzy..... you're right. A $40 solution almost sounds too good to be true.
Southshore..... if I hadn't found the fender, that would have been exactly what I was looking for. Thanks.
Chef...... Thanks for the idea. The pushpit braces and backstays guide it all the way to the lowest horizontal part of the transom. I don't think the webstraps would hold it off the paint at the bottom and wouldn't help when boarding or returning.
Jeanneau 54DS
Minnewaska is offline
Thumbs up to Dan Fender jrd22 Gear & Maintenance 2 09-03-2009 11:27 AM
Fender Boards nereussailor Gear & Maintenance 12 07-02-2009 09:16 AM
Fender covers - any use? ardoin Gear & Maintenance 14 05-08-2009 08:31 PM
Fender marks... bettyswollocks Gear & Maintenance 12 11-13-2008 01:21 PM
Fender idea JohnDrake Gear & Maintenance 2 04-18-2002 07:25 PM
