Old 03-26-2011
scraph is on a distinguished road
SmartPilot X-5 Wheel Drive Unit "Upgrades"?
I'm guessing there are a handful of other engineers on this site, at least. I'm about to get my hands on the Raymarine X-5 SmartPilot Wheel autopilot setup. I read post after post of the problems with these units (which I'm assuming is similar to restaurant reviews ... you only hear from those disatisfied). I understand that they aren't the strongest devices on the planet ... and below-deck autopilot, blah, blah, blah. Has anyone, if only for the sake of challenge, tore into these drive units with component upgrades in mind? Whenever I hear "weak units" in any instance I begin to look for my own solutions. I hear about "cheap plastics parts" always failing in these ... has no one fabricated their own components out of stronger materials?
I have no desire to hear grunting about below-decks autopilots or cries of "it's not worth it" because to some, myself included, tackling engineering problems are worth their own weight. Let me hear what any of you, if any, have accomplished in this vein.
1981 C&C 32
Old 05-26-2011
RyanProvidian is on a distinguished road
I'm installing one in my C&C 34 now. I will let you know how it gos?
Old 05-26-2011
SVPrairieRose's Avatar
SVPrairieRose is on a distinguished road
I would love to see metal gearing in the drive unit as I have done one warranty swap out after less than a year of service. The opportunity is there but it would as you suspect be pricey to re-engineer with proper gearing.
Old 05-26-2011
JSailer's Avatar
JSailer is on a distinguished road
I installed the X-5 on my O'Day 30 over a year ago and it has performed perfectly. Several overnight trips and hundreds of miles in the ocean in various conditions.
The installation was very simple and easy.
The only thing I have not been doing is to rinse off the drive unit fresh water after use (guilty...) so the drive was a bit noisy after not being used for a few weeks but now that I have been rinsing it, it is not a problem anymore.
Oops.. Just realized after writing this that you were asking more about upgrade ideas...
Sorry, none here so far.
O'Day 30
South Florida
Old 05-26-2011
cghubbell's Avatar
1977 CS27 ~ Ravat
cghubbell is on a distinguished road
It sounds like something that could be done if you were a machinist, or had access to one easily. At that point you could probably keep the CNC files and duplicate them as an "upgrade kit" which would make a killing!
I think that any part you can see in plastic could be swapped out for some form of metal, but no doubt the gears are highly unique and proprietary in dimension and would need to be duplicated with CNC. That could be expensive if you weren't doing the work yourself.
I love the simplicity of the X5, and love the idea of having something a bit more rebust. Not sure why they don't offer it, as it would still be WAY below the cost of having a below-decks AP installed.
CS27 #1254 ~ Ravat
Port of Rochester
Lake Ontario
Old 05-26-2011
Cptken is on a distinguished road
I think all the important pieces on the X5 are at least as robust if not more so than on the 4000 series it replaced. The outer wheel shell which a is basically just a cover seems flimsy, thus the reports of poorly built. We must have 40 of the units in our YC, have heard no complaints of breakage. The one feature that I do not like is the response resets to 5 (max) every time it powers up, easy enough to reset, just seems like an unnecessary step.
Old 05-26-2011
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
I cannot help re upgrading the unit but its obvious that the X5 is fine for light - medium use but is not likely to be up to the task for heavy duty work on a daily basis. I'd be very interested to hear further reports from PrairieRose.
Cptken ... I'm not looking at the manual but if I remember rightly you can adjust the response reset auto number to reset to the number of your choosing. Its in the setup menu.
Old 05-26-2011
I think you can set those parameters "permanently" in User Cal....
1984 Fast/Nicholson 345
Old 05-26-2011
tdw's Avatar
tdw tdw is offline
just had a look at the manual on line .. page 49 of the Installation Setup manual. It is in Section 4.3 User Calibration.
Old 07-08-2011
Skipper26's Avatar
Skipper26 is on a distinguished road
in my limited experience (3 trips, about 100 miles sailing alltogether) the drive unit is not a problem at all on my 26 ft boat. The problem is the course computer. My course computer likes to take a siesta whenever it gets a little warmer. It will simply "go to sleep" without warning. Very annoying.
So, I am considering an upgrade, I have two old CPU cooling fans, will make a couple holes in the box and make them blow air in and out.
Tartan 34C "upgrades" wumhenry Boat Review and Purchase Forum 10 01-22-2012 05:34 AM
Yanmar KM3V "V" Drive casey1999 Diesel Engine Forum 2 05-12-2011 05:58 PM
Catalina 25 "Upgrades"? SpcAlan1 C25 and 250 5 07-07-2010 08:30 PM
A spinoff from the " what do you drive " thread poopdeckpappy Off Topic 34 04-29-2008 01:24 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
