Old 03-27-2011
Marcvet is on a distinguished road
SSB Antenna
I have my backstay insulated for use as an SSB antenna. I need to replace the backstay and was thinking of using a 23' fiberglass antenna on the stern rail to avoid the cost of swedging on new insulators. Any thoughts on this?
Thanks
Marcvet
s/v Gantman
Old 03-27-2011
KC9SGV is on a distinguished road
Whip antennas are great.
Hi there,
HF whip antennas work great with automatic or manual antenna tuners.
And if the rig ever comes down in mid ocean.....then you will still have that whip to call for help.
See other HF antenna options from the left hand links here:
Great Lakes Marine Mobile Net
Bernie,
KC9SGV
Old 03-27-2011
billyruffn's Avatar
billyruffn will become famous soon enough
How do you like the looks of a 23 ft whip?
Old 03-27-2011
SSB Antenna
A 23" whip on my stern rail would look a hell of a lot better than some of the other crap there!
Old 03-27-2011
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
I'm just wondering exactly how you plan to replace the backstay and install a 23' whip close by?... How big is your boat?
I'm assuming the new backstay will be earthed, otherwise someone might get a fright when you transmit. Are you sure having a earthed backstay that close won't affect your transmission pattern?
Just checking that you've thought it all through...
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
What is this antenna? tausap Gear & Maintenance 11 03-26-2009 06:27 PM
vhf antenna for tv scosch Gear & Maintenance 3 03-16-2009 06:24 PM
wi-fi antenna westerly Gear & Maintenance 6 06-16-2008 09:23 AM
VHF antenna demetrik2 Gear & Maintenance 2 01-14-2004 05:18 PM
gps antenna capedoryus Gear & Maintenance 3 01-07-2003 12:39 AM
