Old 03-27-2011
chrisncate's Avatar
Mango intolerant
chrisncate is on a distinguished road
Looking for a low windage, low maintenance, simple electrical system solution
Old 03-27-2011
btrayfors will become famous soon enough btrayfors will become famous soon enough
What are your cruising plans? What area?
Will you spend most of the time at anchor? In a marina with shorepower?
Solar is much lower maintenance than any other solution. Panels can be mounted above the bimini and, with a good MPPT controller, will put out reliable power.
However, you really need to do an estimate of your daily power consumption. Use one of those MacBooks to figure it out (with a spreadsheet).
You didn't mention refrigeration.
From what you described, sounds like about 100 amp hours to me, so you'd want to have a system capable of regularly delivering that much power.
RE: batteries, you'd want a minimum of 300AH capacity if you're regularly using 100AH per day.
Bill
Old 03-27-2011
Izzy1414's Avatar
..........huh?..
Izzy1414 is on a distinguished road
Ditch the macbook requirement, Chris. Give yourself (and us) a break, at least while you're out there sailing.
S/V Boccata d'Aria
I'm not sure what Dickens are, but I think they may be important and I sure as hell don't want them scared out of me.......Izzy
Old 03-27-2011
GaryHLucas is on a distinguished road
Sounds to me like this guy is working with his Mac Books and phones, and you want him to be unemployed too?
Gary H. Lucas
Old 03-27-2011
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Methinks yon Izzy taketh the piss !!
I was also going to ask about refrigeration. No mention of it on your site Chris. If you do intend having refrigeration it makes a huge difference to your power bill.
I'm not questioning your decision but why do you need the two MacBooks ? If you could get away with only the one, again a big saving in power. Same goes for phones to some extent.
Right now you have one 80w panel, correct ? Either you are going to have to double that or get a wind generator, maybe even both. Do as Bill says and make up that spreadsheet. You are going to have to get this right cos without that engine there is no quick top up available to you.
ps - pics on your site show pressure water .. you sticking with that or going manual ? What if anything are you doing for hot water ?
pps - not on the power consumption subject but is that really a non gimballed stove ?
Old 03-27-2011
Izzy1414's Avatar
..........huh?..
Hehe, I was only being partly facetious .... the (and us) part. The computers and phones do add to (complicate) Chris' requirements significantly enough to question how much he needs those trappings of society on a vessel that most of us use to escape said trappings ..... OK, I've made my practical point, now I'll step down from my soapbox. Carry on ...
S/V Boccata d'Aria
Old 03-27-2011
chrisncate's Avatar
Mango intolerant
Old 03-27-2011
chrisncate's Avatar
Mango intolerant
Old 03-27-2011
mitiempo's Avatar
You should have a battery bank capable of supplying lasting 2 days without charging as a minimum, maybe 3 days. Only half of your AH are usable. If your daily usage is 100 AH, that means a 400 to 600 AH battery bank giving you 200 ti 300 AH usable.
The best affordable way to achieve this and end up with a long lasting durable bank is with golf cart batteries. 4 6 volt in series/parallel will give you a 450 AH bank, 6 will give a bank of 675 AH.
Solar is the low maintenance quiet solution. You don't say where you are going to be which will make a difference. In a climate like Florida 2 135 watt panels should almost give you 100 AH per day based on 5 hours at full output.
Someone with real world solar experience may post the real numbers.
If you bought one netbook and saved the Macbooks for when on shorepower it would make a huge difference to the energy budget.
Brian
Old 03-27-2011
chrisncate's Avatar
Mango intolerant
Help: Simple Shore Power System YeahJohn Electrical Systems 52 01-26-2011 10:10 AM
Simple electrical system question radioguy Electrical Systems 9 08-15-2010 08:25 PM
simple system to do most of wind/solar/alternator/shore to house/starting/dump + more Bene505 Electrical Systems 30 02-24-2009 04:21 PM
Electrical System Trouble RogerHardman Gear & Maintenance 0 05-28-2006 07:33 PM
Electrical System Ground Tracuman Gear & Maintenance 10 05-09-2006 05:45 PM
