-   -   Removing lag screws corroded on strainer thruhull (http://www.sailnet.com/forums/gear-maintenance/73159-removing-lag-screws-corroded-strainer-thruhull.html)
Goblinfog 03-28-2011 10:20 AM
After removing my strainer thruhull to rebed, found that instead of using 4 bolts and nuts to secure the strainer through the hull, lag screws were used. Now I have 4 screws(heads are corroded off) going completely through my hull. The tips of the screws are just breaking through the inside of the hull. Any easy way:laugher to remove these:laugher. Also could I use epoxy to fill the holes afterwards, or would i have to reglass.
Barquito 03-28-2011 03:34 PM
Maybe drill out the lag screws, then replace with through bolts?
