Lightning Class Sailboat - SailNet Community
post #1 of 11 Old 03-28-2011 Thread Starter
New owner of a Lightning - Newport Boats 279. Needs some TLC & repairs. Any suggestions for suppliers, etc. would be appreciated
Flowerman is offline
post #2 of 11 Old 03-28-2011
Tartan 27' owner
CalebD's Avatar
Check here: ILCA Manufacturers / Equipment List
Allen and Nichols still make Lightnings.
Check the lightningclass.org website too. They have a classifieds section for folks to sell parts and boats.
APS sells a bunch of Lightning gear/accessories: APS - Lightning Sailboat Parts and Accessories
Fun, fast boats.
Everybody has one:
CalebD is offline
post #3 of 11 Old 03-06-2012
Send a message via Yahoo to Radicalcy
Re: Lightning Class Sailboat
Almost exactly a year later......I just picked up Newport Boats Lightning hull #249. This is a
fiberglass boat, with wood trim. Nowhere near the sophistication of the newer boats, and the hull # isn't in any sequence with the Class boats. It's probably a Cali boat, as it had a Cali license plate on the trailer. Wonder if anyone can identify the year it was built?
Radicalcy is offline
post #4 of 11 Old 03-06-2012
Tartan 27' owner
CalebD's Avatar
For a few years I had Lightning #11046. I called the ILCA class office and they looked up the maker for me which turned out to be Clark. They might know more about Newport made Lightnings. Worth a shot. Welcome to the International Lightning Class
Not all Lightnings were set up with full racing rigging and the boat can be sailed just fine with just a basic setup.
Everybody has one:
CalebD is offline
post #5 of 11 Old 04-04-2012
I bought a 1968 Lippincott last year. A little dowdy, but nothing some paint, elbow grease and a new rub rail won't cure.
Great Lakes Skipper and Jamestown Distributors look to be pretty good.
kharlowrhodes is offline
post #6 of 11 Old 09-29-2012
Question Lightning centerboard extraction
I have lightning and am wanting to extract the centerboard to remove the paint. Any suggestions on a one man extraction? Is it possible to extract with the boat on the trailer?
Keifp is offline
post #7 of 11 Old 10-04-2012
Keifp,
The board weighs about 300 pounds and to remove it, you remove the pivot pin or bolt on the bottom front end of the trunk. The board then drops out of the bottom of the boat. I can't imagine any way it could be done with the boat on the trailer.
James
jtsails is offline
post #8 of 11 Old 11-23-2012
Dane
Hi,
New to the forum.
I have 2 old wooden lightnings that I'm restoring (#9469 & #4677). Both have mast steps that are quite different and rotten. The plans have very little detail on mast steps, and even though I wrote to the Lightning Association, I never heard back from them. Does anyone out there have any pictures, drawings or other details on the Lightning mast step or know where to find any of these? Thanks,
Dane
dfjensen is offline
post #9 of 11 Old 11-23-2012
Tartan 27' owner
CalebD's Avatar
Dane,
I have found that it is best to actually use the phone to call the ILCA office. If you can get the right person on the line they can look up the mfr'r of your hull #s (9469 & 4677). They should be able to tell you the builder which, with more research may point to how the builders implemented the mast step.
On the Lightning I owned (#11416, frp by Clark) the mast step was a metal track or channel perhaps 3" wide (wide enough for the mast to fit into) that used bolts to adjust the fwd/aft rake of the mast foot step. The sides of the channel had many different holes for the bolts so it was adjustable, with some fumbling.
You may be able to design a more elegant adjustable setup for the mast step. I'm thinking more along the lines of a main sail traveler car. If you are interested in racing these boats the 1 Class rules are quite specific as to what hardware is allowed, or not. If you are just doing it for fun then have at it.
Your email address has your website in it: Dane F. Jensen Design
Enjoy.
Everybody has one:
CalebD is offline
post #10 of 11 Old 06-01-2014
Hello....just acquired a Lighting. Hull 13124. Need more information on rigging and such. Also really need to buy a new rub rail. I hope they have a rubber one. Any ideas where to find some? Thanks!
Ontheroadgiv is offline
Sailboat Salvage, Lightning Striker, Lancer 36, Blisters, Hull Moisture epatter Boat Review and Purchase Forum 7 04-15-2009 05:12 PM
1975 Lightning Sailboat on Ebay kai34 Boat Review and Purchase Forum 0 11-13-2008 08:13 PM
a sailboat and sailing orientation class? deniseO30 herSailNet 9 08-02-2008 08:22 PM
Family's sailboat lost to lightning strike - KXLY NewsReader News Feeds 0 06-10-2007 02:15 PM
Family's sailboat lost to lightning strike - KXLY NewsReader News Feeds 0 06-06-2007 10:15 PM
