04-03-2011
No screws necessary. Use moderate clamping pressure, just enough to hold the two pieces together. Do not glue-starve the repair. Use clamping cauls to keep the two pieces level with each other. To reduce your work after the repair, use blue masking tape to cover the wood immediately next to the repair on each piece, on each side (about 1/16" from the edge). When done, do not try to sand the excess epoxy (the heat will soften the epoxy and gum the sandpaper) that will inevitably ooze out. Use a cabinet scraper - it's faster and gives a much cleaner finish. Light sandpaper (220 grit) after that.
I've done this repair many times on many projects with no joint failure.
Sabre 38 "Victoria"
