Old 03-28-2011
rbrasi's Avatar
rbrasi is on a distinguished road
Through Hull Replacement question
My boat is a 1968 Cal 2-30 and I'm replacing the through hulls. There is one right above the keel that has an impeller knot-mater. It still works, but I'll never use it. So the question is:
Do I yank the whole thing out (and cover the hole) and rely strictly on electronics?
Common sense dictates that if it ain't broke, don't fix it, but I would rather have one less hole.
1968 Cal 2-30
Sandpiper 2
MDR
Old 03-28-2011
SVPrairieRose's Avatar
SVPrairieRose is on a distinguished road
The difference between gps speed over ground value and knotmeter speed through water value lets you know if the current is helping you or hurting you, usefull information. Make sure the fitting and transducer are in good shape and keep on sailing!
Old 03-28-2011
fallard is on a distinguished road
SVPrairieRose has it right. It looks like your sailing venue includes the California current, so it may be useful to compare your GPS speed with speed through the water, particularly if you cruise to places where the tidal effect is significant (SanDiego?).
Old 03-28-2011
I wouldn't want to be without my through-the-water boat speed when trimming and steering upwind either.... Always good info to have.
1984 Fast/Nicholson 345
Old 03-28-2011
oomfh is on a distinguished road
Originally Posted by rbrasi View Post
Common sense dictates that if it ain't broke, don't fix it . . .
. . . If it ain't broke, you're not trying . . .
Red Green
Ranger 33 Through Hull Replacement jerkeene Ranger 3 08-01-2011 08:31 PM
Another Halyard Replacement Question SailinJay Gear & Maintenance 4 06-28-2007 10:27 PM
Newport 30 Thru-hull replacement dasnider Newport 6 06-16-2007 09:09 PM
Thru Hull Replacement Stormer_2003 Gear & Maintenance 1 09-13-2004 11:22 AM
Thru Hull Replacement Stormer Gear & Maintenance 4 08-03-2004 08:21 AM
