Auto or Manual Bligle Pump for my little 17'er? - Page 2 - SailNet Community
post #11 of 21 Old 03-29-2011
A manual pump would be perfectly acceptable. Just to be sure, isnt' there a small cabin in front? Not exactly the same as a laser or sunfish with bailing cups.
Is the cockpit floor right on the hull, no deck? If you meant that you can see into the cabin bilge, there can be a reason for an auto, since that probably isn't totally clear.
Nevertheless, manual is still fine.
Jeanneau 54DS
Minnewaska is offline
post #12 of 21 Old 03-29-2011
old guy :)
rikhall's Avatar
What are the legal requirements where you sail?
Me, my personal option would be a manual bailing device (hand pump or bucket, depending upon requirements) and a really good sponge.
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #13 of 21 Old 03-29-2011
Sabreman's Avatar
I think that you need a 30,000 GPH gas powered pump with auto sensors, auto start, and Internet connection to alert SAR. Optionally, you could add auto-inflate, auto-deployable airbags with rocket deployed flare launchers
Seriously, a bucket is very adequate (you need one anyway). For real luxury, you can use Whale Gusher or equivalent. On our first boat, a GP-14, we only had a bucket. I worked two several rental yards and we only supplied a bucket for up to 18'. The beauty of small boats is that they don't hold much water and a bucket will evacuate the boat very fast. Our last boat, a Sabre 28, only had a manual pump. I am fanatical about any water intrusion as a result. Leaks don't "just happen", there is nearly always a warning sign of some sort.
Sabre 38 "Victoria"
Sabreman is offline
post #14 of 21 Old 03-29-2011 Thread Starter
Montgomery 17
Perithead's Avatar
Thank you all for the fantastic replies!
I think I will go with a manual pump like a Whale Gusher. I will have it mounted so that pump can be used from the cockpit.
A Montgomery 17 isn't really a daysailer although it is a small boat. In the recent past, a M17 has been single handed half way around the world. It's the tank of small trailerable sailboats.
Small is beautiful, simple, cheap, and easy......
Sailing Videos, Woodworking Videos and More!
Perithead is offline
post #15 of 21 Old 03-30-2011
On my Monty-17 there was a sump in the keel behind the centerboard trunk. I put in one of the whale thru-deck manual pumps. 1" hose was the biggest that would go to the bottom of the sump. I rarely used it except for testing...
scotthenry is offline
post #16 of 21 Old 03-30-2011
Allanbc's Avatar
On my Monty 17, I just had a bucket to bail. I never needed it. I sailed it on a lake so I reasoned that I could run aground faster than I could bail.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Allanbc is offline
post #17 of 21 Old 03-30-2011 Thread Starter
Montgomery 17
Perithead's Avatar
"run aground faster than I could bail" thats pretty funny!
I plan on heading down to the Florida Key's in the fall with every intention to hop over to the Bahamas if I get a weather window. I think I may need more than a bucket, but what do I really know?
I will probably go with the Whale Gusher with the 1" hose run into the sump. Thanks scott for the confirmation.
post #18 of 21 Old 03-30-2011
Allanbc's Avatar
That is a good way to go. If I had kept my Monty, that is what I would have done. That is a fun little boat, I am jealous.
Allanbc is offline
post #19 of 21 Old 03-30-2011 Thread Starter
Montgomery 17
Perithead's Avatar
Your jealous? With that mamoth you are sailing around in? Beautiful boat, and a ketch is so unique looking....
post #20 of 21 Old 03-31-2011
There is another train of thought that is, in my mind, equally logical to 'its a small boat so bring a bucket'. That train of thought is ... the smaller the boat, the less water it takes to sink it, and the faster it will sink. Small bilge pumps (automatic or manual) are really no different in the fact that they won't keep up with any amount of active flooding. If you are only talking about small capacity bilge pumps and you simply want them for the convenience of routinely removing water from the bilge that has accumulated some inventory ... it doesn't matter which you get ... and a bucket would work just as well.
If your intention is to install a bilge pump as a safety item then you want more than one, you want a small automatic one, and you want the other/s to be of reasonable capacity. The small automatic bilge pump would serve the purpose of routine dewatering (lesser power requirements for routine operation) but would also serve as a warning if you are experiencing flooding (the pump starts to run and keeps running...). I have a 20' powerboat, in addition to the sailboat, and the design basis for my bilge pump capacity is to be able to keep up with the flood rate if my largest and deepest thru-hull is wide open into the bilge (and they do). Any less than that and you might as well not worry about it ... because your bilge pump isn't a safety item anymore.
1981 C&C 32
scraph is offline
manual bilge pump billdre O'Day 1 05-19-2010 08:39 PM
Manual to Auto bilge pump RocktheBoat Gear & Maintenance 0 06-23-2009 07:44 AM
Manual Bilge Pump backcreeksailor Gear & Maintenance 13 04-18-2009 01:02 AM
manual oil pump wumhenry Gear & Maintenance 3 07-02-2007 02:35 PM
Auto vs Manual SOSpenders pixurman Gear & Maintenance 4 05-05-2004 07:31 AM
