Old 03-28-2011
eckcn17 is on a distinguished road
Name removal (paint)
Hi!
Just wondering what the best method/products for removing the painted on name on my boat. It is a 1987 and the gel-coat is white. The name is multi-colored and is painted on.
I will be using a decal for the new name.
Thanks again as always for the help.
Chris
Old 03-28-2011
Irrationally Exuberant
arf145 is on a distinguished road
I had the same situation a few years back. I used citrus-type paint remover, which removed the paint fine and didn't seem to hurt the gelcoat--I rinsed it off thoroughly. Since the name had been on there a long time protecting the gelcoat, it did leave a ghost of better gelcoat behind.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 03-29-2011
DrB DrB is offline
DrB is on a distinguished road
Easy Off Oven Cleaner
I have heard that works too on some paints. I would test in a small area first.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
Old 03-29-2011
Bilgewater's Avatar
Hmmm
Bilgewater is on a distinguished road
I have used easy-off oven cleaner in the past and it works very well. However, as previously pointed out it will leave behind a ghost of newer gel coat. But in my case, once the new lettering was applied it's not really that noticeable from a short distance and I was pleased with the overall result. Try it on one letter to begin with to see if your happy with the result.
Impulse III
Truant Pilothouse
Old 03-29-2011
Silvio's Avatar
Battered and Bruised
Silvio is on a distinguished road
+1 for the easy off. Used it on 8 year old painted on name and it worked well. Left a ghost of brighter gel coat but that will fade in time. Let it sit and work for 10-15 minutes and the paint should wipe off with a paper towel. Rinse well when done. Wear gloves and eye protection is a good idea.
Old 03-29-2011
dennismenace111's Avatar
dennismenace111 is on a distinguished road
To remove the ghost of the old name in Gel Coat,,,,wet sand with progressively finer sand paper starting with 600 and going as fine as you can go...then get the rubbing compound...it can be brought back to life with some elbow grease....
As I cast off for that very first time,
The "rope" in my hand has now become "line".
And hauling the sails to the top of the mast,
That "rope", now a "halyard" holds strong, taught and fast.
Then sailing in brisk winds full force on a beat.
The sails are trimmed in by that "rope" that's a "sheet".
And now at my anchorage with sails safely stowed,
I trust in that "rope" that now serves as a "rode".
Through all my life I will never lose hope,
Of a reason or time to play with a rope.
Old 03-29-2011
MarkofSeaLife's Avatar
MarkofSeaLife is on a distinguished road
I used my girlfriend.
It took hours and she used a lot of fiberglass polish. But she finally got it off by dinnertime. It must have been fun because I heard lots of girly screams.
I hate late meals
Good luck.
Mark
Sea Life
Notes on a Circumnavigation:
Old 03-29-2011
Another gelcoat-friendly stripper is 'Aqua Strip', available on-line. We used it to remove old chalky hull stripes. It's a gel so it doesn't run off the vertical surfaces while you give it time to work.
1984 Fast/Nicholson 345
Old 03-29-2011
blt2ski's Avatar
I used a combo of Goof Off, and a fine plastic 000 steel wool equal. Goof Off is a petrol based paint/oil type cleaner. Fingernail polish is another option.
Marty
She drives me boat,
I drives me dinghy!
Old 03-29-2011
sawingknots's Avatar
sawingknots is on a distinguished road
lacquer thinner works very well and fast,just wash imediately with soap water
Lettering paint removal Bobio Gear & Maintenance 5 07-14-2010 06:54 AM
paint removal? Mick Young Gear & Maintenance 10 03-19-2007 03:29 AM
Name/Paint removal garrettav8or Gear & Maintenance 7 08-06-2004 09:57 AM
bottom paint removal jharrison Gear & Maintenance 7 01-09-2002 08:25 AM
Paint Removal hilly50 Gear & Maintenance 2 07-08-2001 06:34 AM
