03-29-2011
Sailing to surf
Marine Plywood & Bulkheads
I am needing to replace many of Windsong's bulkheads and cabinets due to a lot of rot from years of neglected leaks.
I am having trouble finding a local supplier of marine plywood, and am not too excited about the price of what I have seen out there. I plan on using marine plywood, so don't get on my case too hard...I'd just like to see if the alternatives are suitable for above the waterline, and in theory, dry work.
So, must I use marine plywood for interior cabinetry and bulkheads? I plan on covering each piece of wood I use with epoxy to seal it up and prevent water intrusion, but I know that isn't 100% effective in the long run. I'd love to be able to save some cash and time by not having to find and use marine grade plywood, but if the argument for using it is compelling I will stick to that route.
(and before some smart guy says I should worry about the leaks first...yes, I've got that covered  )
My boat rebuild/sailing blog: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Please read and provide comment to my entries!
