Alcohol to LPG - Page 6 - SailNet Community
post #51 of 54 Old 08-05-2011
aeventyr60's Avatar
Originally Posted by mitiempo View Post
Solman
Here's a pic of it almost finished. Trim to go still.
Brian,
Which stove is that? Does it have a broiler? Nice instal.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #52 of 54 Old 08-05-2011
mitiempo's Avatar
Thanks
It is a Force 10 3 burner with oven and grill. I bought it in the late 90's for a previous boat but sold the boat without it. They are a bit different now - they have a glass oven door and the oven is thermostatically controlled now. Great stoves.
Brian
mitiempo is offline
post #53 of 54 Old 08-06-2011
Stu Jackson's Avatar
Yes the top of the stove is not much bigger than the 2B but that large back burner on the 3B has to be a boon.
I've always found 3 burner stoves questionable. Even with two pans going, there's not much room on the cooktop. Thanks to this discussion, I learned that there is a bigger burner for bigger "fry(!)".
Given the size of your boat, only YOU can decide how you want to use it, with the options presented.
Some folks can actually leanr to use their pressurized stoves. We did on our C22. When we bought our C25, it had one that was knackered. We replaced it with a 2B Origo, non-gimballed. No way one could cook on a small boat, and if we needed to I would have bought one of those bulkhead mounted gimballed units for making hot water. I opted for a thermos!!!
We have CNG now, in San Francisco. Supply of CNG is very close to our marina, hence, no worries about backup, plus we have two CNG tanks aboard. Backup is my middle name, until we bought an empty CNG tank and making coffee that morning became impossible.
No one mentioned this: CNG tanks are BIG and HEAVY, like oxygen tanks in hospitals, only painted white, not green. CNG would NOT be an option on your boat, even if you were my dockmate with easy access to replacement tanks.
Forget CNG and most folks know the issues about heavier and lighter than air.
Do you like scones? Then get an oven and do what Brian has done - great job there, looks and works great.
A drop-in ORIGO would work wonders for your peace-of-mind.
A propane system would be another choice, with its demonstrated additional components.
Other than visiting other countries (i.e., Canada and Mexico - west coast bias since my boat is here!), I'll keep my CNG (it works for us), then would go to alcohol non-pressurized (could still get an oven from Origo), then propane, LPG or whatever they're calling it this week - cooking fuel?).
Your boat, your choice.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #54 of 54 Old 08-07-2011
bljones's Avatar
We have a non-pressurized, non-gimballed, seriously obsolete old-skool Almatic amcolhol stove. We cook EVERYTHING on it. Every meal documented on our blog comes from that simple little stove. We have a Magma grill which used to be mounted on the rail - it is now in our shed- we used it once. It may reappear onour boat this season, but on the pulpit instead of the cockpit- it was so inconvenient to use on our small boat, compared to our galley stove, that it rarely got used.
Yes, you CAN cook on a small boat. We do.
It's 5 o'clock somewhere:
bljones is offline
alcohol stove KenD Gear & Maintenance 18 11-12-2009 07:04 PM
Alcohol MiVelero General Discussion (sailing related) 12 09-04-2009 10:50 PM
Using an alcohol stove Bermuda30 General Discussion (sailing related) 10 09-19-2007 12:11 PM
Alcohol and skippering: do you or don't you? Valiente General Discussion (sailing related) 133 06-26-2007 01:27 PM
