Old 04-03-2011
argofred is on a distinguished road
Diesel fuel lines - universal 3 cyl
All: Just having replaced all filters for the season I found that the fuel line from the pump to the secondary (spin on ) filter is in need of replacement. They all probably should be replaced actually. One end is a brass fitting with the hose crimped on fitting while the others have brass fittings (fine pipe threading?) on both ends. If I remeber the lines can be made by the right shop. Nobody seems to stock generic equivalents so will a good marine engine shop be able to make them? Thanks!
Old 04-03-2011
mitiempo's Avatar
Yes, or any shop that works on either commercial trucks or hydraulics should be able to help as well. Will be less expensive than a marine shop as well.
Take the old lines to them and they should be able to duplicate them. Label them as to location.
Brian
Old 04-03-2011
olson34 is on a distinguished road
Lightbulb
When we replaced the supply and return lines on our M25XP, I found that the factory had installed copper from the tank to the filters and a hose was used for the return.
I replaced both with new USCG-approved fuel hose. All fittings are nowadays barbs with clamps.
(The original copper had narrowed up inside over the years like a bad artery.)
No problems since.
I also changed the threaded fittings on the Racor and the tank exits.
Parts should be at any industrial hose supplier that deals in fuel and hydraulic products.
L
Diesel fuel lines -Universal 3cyl diesel argofred Diesel Engine Forum 8 04-18-2011 03:39 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel Engine Forum 4 06-07-2010 09:01 AM
Universal M25 Diesel Fuel Pump flreflections Diesel Engine Forum 2 04-09-2010 01:58 PM
clean out fuel lines mauidan15 Gear & Maintenance 2 04-21-2008 10:45 AM
Universal 5411 Fuel System cooltec Gear & Maintenance 4 08-17-2006 12:28 PM
