Old 04-04-2011
ereiss is on a distinguished road
Rubber isolators needed
On my old Air-x there are (or should be) rubber isolators to isolate the diagonal stays from sending noise down through the L brackets that are fitted on the boat. Southwest Wind will only sell me the entire bracket assembly ($29.00 plus shipping). And can give me no data as to what these isolators are or where they get them from.
I'll post a picture of the arrangement when I get home.
Any thoughts would be appreciated.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
Old 04-04-2011
Like this??
They don't look too 'special'.. a good hardware store should have a collection of rubber bushings that might be made to work. Also try automotive parts stores for firewall bushings or grommets.
1984 Fast/Nicholson 345
Old 04-04-2011
Yes, that's it. Southwest Wind couldn't tell me whether it was a two piece unti (I would think it has to be) or not as it goes on both sides of the L bracket.
Thank you for your help.
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
Old 04-04-2011
treilley's Avatar
treilley is on a distinguished road
If you have one or have the dimensions, I would try McMaster or your local Napa store. Mine are presently down for winter. I will check their size when I get home. I should be able to provide you with the specs.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
and
Old 04-04-2011
A generic product like what's on the link below might be workable if the dimensions match:
GROMMET RUBBER .250"DIA .562"L - 739
They may be one piece and will need to forced into the L bracket, similar to that one in the link.. btw look around their site, they seem to have a variety of types.
galvanic isolators and the green wire mitiempo Electrical Systems 6 06-08-2009 01:43 PM
Galvanic Isolators Gulfislander Gear & Maintenance 1 06-11-2007 05:38 PM
Engine mounts vs isolators ikent Gear & Maintenance 2 08-03-2004 05:17 PM
Galvanic Isolators Tom Wood Gear and Maintenance Articles 0 08-06-2002 08:00 PM
Isolators rpowell Gear & Maintenance 1 01-21-2002 11:09 AM
