Replacing seacoks + how to grind down old fiberglass around old gate valves. - Page 3 - SailNet Community
post #21 of 23 Old 05-05-2011
Lightbulb Sea Cocks
While some sailors will defend one make or material over another with near-religious fervor... I have installed bronze one-piece seacocks and the current Forespar one-piece Marlon seacocks and like them both.
If you worry much about electrolysis, then go with the Forespar.
Mitempo's advice is short and to the point.
We have frp backing plates and our Forespar valve bodies are epoxied in place, with the external lip ground off to give us a theoretical added nano-knot or two of speed...
So do a good strong install and sleep well at night.
Here is a pretty good thread link, with further links mentioned in reply #7.
(Lots of opinions, but educated and forthright...)
Thru hulls and ball valves - EY.o Information Exchange
Cheers,
LB
olson34 is online now
post #22 of 23 Old 05-05-2011
mitiempo's Avatar
I just finished reading several emails from the Catalina 30 group on Yahoo (which I belong to) about cracked Marelon seacocks. I have never heard of a good bronze seacock cracking. Especially in the smaller sizes (under 1") the Marelon are more fragile I think.
Brian
mitiempo is online now
post #23 of 23 Old 05-09-2011
I drilled out the old nipple with a hole saw sized for the new through hull, and lacking a good grinder, took out the "volvano" bit by bit with a plastic cutting attachment on my Dremel, and then used ~30 grit on my palm sander to smooth/rough up the job.
donlofland is offline
Thru-hull valves: Ball or Gate? Classic30 Gear & Maintenance 26 10-21-2010 07:36 PM
blanking gate valves aquagee Gear & Maintenance 2 04-26-2009 12:03 PM
Gate valves and why we don't use them... sailboy21 Gear & Maintenance 28 11-12-2008 10:55 PM
Newport 27 Thru-hulls and Gate Valves jimmiebuchanan Newport 8 07-26-2008 06:16 PM
Gate valves, with scary photo pmoyer Gear & Maintenance 61 04-11-2007 12:55 PM
