Old 04-04-2011
BobfromSWOhio is on a distinguished road
Friction Winch
Does anyone have a source for a (hopefully) reasonably priced, small friction winch? The winch to raise/lower the CB on my O'Day Mariner is shot and a small friction winch should prove to be a good replacement Any and all help is appreciated.
Old 04-04-2011
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Go down to your nearest boating/camping/fishing store and buy the smallest, cheapest single-speed trailer winch you can find.
That's all you need.
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 04-04-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Good solution, but, not as handy as a friction winch. For the complete overkill solution:
Catalina Direct: Keel Winch with Handle
Or what about just a block and tackle?
Old 04-05-2011
heinzir's Avatar
Junior Senior
heinzir is on a distinguished road
Check out these: brake winch from Northern Tool + Equipment
The 1200lb model is the one used for replacement on most older Macgregor/Venture swing keel boats. The 800lb unit will probably work fine on your boat. I use that one for my mast raising system.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
Hunter 31 question - throttle friction lock bobmorning Gear & Maintenance 6 03-29-2011 03:26 AM
Need to add friction to Teleflex engine control? mbsl98 Gear & Maintenance 8 09-14-2010 04:36 PM
Need one winch casacitaii General Discussion (sailing related) 2 07-04-2009 09:31 AM
Winch Way? garycalvinsmith Gear & Maintenance 1 09-12-2006 08:06 AM
which winch?? maestro Racing 2 03-30-2004 01:47 AM
