Old 04-05-2011
RRaedeke is on a distinguished road
Centerboard Gasket - Bucc 18
I recently bought a '78 Buccaneer 18 - it is in need of a new centerboard gasket.
Nickles Boat Works sells a Mylar gasket and provides help on how to install without the metal trim pieces.
However, I'm not racing this boat and have read that if the intention is to beach the boat, Mylar is not the best choice.
Does anyone have a suggestion or thoughts about using a rubber gasket that might be a bit more forgiving than Mylar. I am considering buying rubber sheeting (like that used in shower pans) and making my own gasket.
Is there a recommended adhesive and or sealant for this? I do intend to use the SS metal trim plates and screws to re-install.
Or should I stick with the tried and true Mylar method?
Thanks for the advice.
Richard
Denver, CO
Old 04-05-2011
jimq26's Avatar
jimq26 is on a distinguished road
I always made my own from stiff sail material.
When I was campaigning my Albacore one-design, I always made my own. I replaced them every year to stay competitive.
Fairly easy to do - just measure the stiff material carefully, fold over and fasten down the open edges with the metal strips. I allowed about a 1/2" overlap in the centre.
Here's a link for gasket material - Parts & Rigging
Old 04-05-2011
Thanks for the thoughts -
Did you use a sealant of some sort?
I can see how the sail cloth would easily slide past one another - Now that you indicate the 1.5" overlap, I worry about the rubber binding against itself.
But if it's easy - I may just give it a shot and see what happens.
Thanks
Old 04-09-2011
jimq26's Avatar
No sealant was used.
I remember doing a zig zag stitching to keep the folded over stiff sail material together where it went under the hold down plates.
Old 04-12-2011
Memopad is on a distinguished road
Kind of heavy to beach the boat isn't it? The gasket is far enough back where even if you got the bow on the beach the gasket probably would still be in the water... depending on what you mean by beaching.
If you're not racing, i'm wondering why replace the gasket at all? Maybe at speed water would shoot up through the trunk if you didn't... I had a bucc 18 last spring and i remember the gasket had been replaced with a thick black rubber. I think just about anything will work there.
1974 Marieholm IF
1978 Ranger 28
A4 gasket link ironworker Atomic 4 1 08-29-2010 06:28 PM
Bucc 25 Alanjp General Discussion (sailing related) 0 03-19-2008 11:49 PM
Hatch Gasket essman Irwin 1 03-18-2007 02:21 PM
Hatch Gasket essman Gear & Maintenance 0 03-03-2007 06:55 PM
Hatch gasket material prussell Gear & Maintenance 3 09-24-2003 06:32 AM
