Old 04-05-2011
Mornar is on a distinguished road
replacing keel/cb winch
Greetings to all,
I am restoring an old Northstar 22 with keel/cb. Presently there is an (fairly ugly !) trailer-style winch inside the cabin to lift/lower the keel. On my previous boat (Seafarer 24 c/b) I had a nice bronze winch mounted in cockpit which was used to lower/raise the c/b. I would like to replace the current installation in Northstar with something like I had on Seafarer. My search on internet returned nothing when searching for (keel / c/b) bronze winches. Any ideas/suggestions what and where to look for ?
One idea I have is to use a halyard winch, something like lvjwinchesusa.com has
Thanks !! Zoran
Old 04-05-2011
souljour2000's Avatar
souljour2000 is on a distinguished road
good c/b winch
Zoran,
I picked up a Seafarer 24 CB last summer and I really like that bronze winch she has since it has a worm gear on the side of the winch housing in a separate housing.This is after having a Hunter 20 with a decent-made but fairly regular trailer type winch. Good luck..I am going down to a great used nautical-type thrift store here in sarasota soon..I will take a look and see if they have anything you could use that is truydy or worm-geared..... I would also check the UK version of Ebay if I were you... Any reminisces about your Seafarer 24 ,anecdotes or advice would be welcome..what did you think of the old girl at the end of the day..? .I like mine lots...but she is in need of a fair bit of work still...thanks and good luck!
Old 04-06-2011
thank you very much for your help - if you do find something in sarasota pls let me know
you can write to me at zorang at videotron dot ca and I will send you some stuff regarding Seafarer... it was a great boat and I will be happy to share my experience etc with you
cheers
Z
Originally Posted by souljour2000 View Post
Zoran,
Old 04-06-2011
AdamHowie is on a distinguished road
Good luck with it, in my opinion I hate swing keels. On the next boat yoou buy, do yourself a favour and go with a fixed keel or at least a shoal draft one.
1977 Laser 1
1980 Edel 665
Dinghy!!! With a 2 horse
Old 04-06-2011
mike dryver is on a distinguished road
souljour2000 is that nautical thrift store on line if so can you tell me name
Keel winch woes. Is this one good? sealover MacGregor 0 06-03-2010 05:01 PM
Replacing a Wire Halyard Winch alofns Gear & Maintenance 8 03-20-2010 09:54 PM
Windrose keel winch jhicksusna Gear & Maintenance 2 08-09-2009 01:39 PM
Broken keel winch mounting Barquito Gear & Maintenance 4 07-07-2009 11:04 AM
keel winch broke loberg00 Gear & Maintenance 0 06-22-2001 06:40 PM
