-   -   Removing Mast Foam (http://www.sailnet.com/forums/gear-maintenance/73404-removing-mast-foam.html)
Michael K 04-05-2011 09:21 PM
Removing Mast Foam
Has anyone experience removing foam from inside a mast? If so, how did you go about it? Techniques that preclude environmental mayhem are most welcome. The nearly bare stick I will start working on pretty soon is ... uh ... 42' long and would be much improved if most halyards could run internally.
mdbee 04-05-2011 10:23 PM
"Techniques that preclude environmental mayhem are most welcome."
Well, I suppose that precludes using tetrahydrofuran, dimethysulfoxide, dimethylformamide, acetone or gasoline.
scottyt 04-06-2011 10:58 AM
gasoline, pour the resultng goop in a bucket, then let it evaporate the left over gas.
Barquito 04-07-2011 09:12 AM
I could imagine pouring acetone or something down the mast in rivers, and having the entire inside of the mast coated with melted foam goo. Not sure if that is what would actually happen.
What about sand blasting or a plumbing auger? (Just trying to think outside the box here)
