Old 04-06-2011
windependent is on a distinguished road
Removing drips/runs under Brightside
I have just returned to my first dried coat of Bightside and there are some drips and runs from the primer layers underneath that weren't visible prior to painting the Brightside. What can I do to make those go away? Can they be toned down at all?
Old 04-06-2011
If they are in the underlying primer there's not much you can do besides refair and repaint. This is where the 'good prep' rule always bites you in the tush....
1984 Fast/Nicholson 345
Old 04-06-2011
tommays's Avatar
I could not even begin to count the hours of wet sanding i did
And worse yet how many i have left
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 04-06-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
I think you would have problems re-doing a small area. The edges won't blend well with brightsides. Operationalize the automobile 20/20 rule. If it looks good at 20 mph from 20 ft. away, don't worry about it.
Old 04-06-2011
"Far from good but good from afar?"
Slider drips - any ingenious solutions out there? JeffBurright Gear & Maintenance 8 10-19-2009 11:44 AM
Interlux Brightside how to!?!? Grizly686 Gear & Maintenance 5 09-09-2009 01:18 PM
Tips for apply Interlux Brightside Poly T37Chef Gear & Maintenance 14 03-26-2008 11:11 AM
PWC runs over dam dorourke Off Topic 9 07-10-2007 07:01 PM
Brightside VS. Easypoxy HeartofGold Gear & Maintenance 9 03-30-2004 07:04 AM
