04-08-2011
If you can, go with Stainless, but that isn't absolutely necessary. What is absolutely necessary is the largest vent line you can manage. Then, never put any chemicals of any kind in the tank. No deodorants, bleach, soap, nothing. You need good bacteria to break down the stuff and that will over run the smelly bacteria. Any chemicals kill the good bacteria. Also, very important is to flush enough water (fresh or salt) to push all the waste to the tank. This is the typical cause of smells that permeate the waste lines.
Jeanneau 54DS
