cutting board as backing plate material? - Page 2 - SailNet Community
post #11 of 18 Old 12-06-2011
asdf38's Avatar
I'm about to add backing plates myself. G10 was recommended and it certainly makes sense but I was thinking about hardwood oak for convenience and cost. Home depot sells 0.5"x6"x4' for $13 that would make several plates. Also in my boat many of these backing plates would be visible and stained oak would blend in nicely.
How much advantage is there to epoxying to the hull? I don't like permanently attaching anything and second, I think I have an interior liner that would make this less useful?
asdf38 is offline
post #12 of 18 Old 12-06-2011
I wouldn't use cutting board, or any other plastic, for a backer plate. Plywood is easy to work and lasts a pretty long time.
Solid stock is not a good idea if you are considering using wood. The cross lamination of the grain in plywood is preferred, it won't split and doesn't have internal tension like a piece of oak. I use 3/4" marine ply for through-hulls and I soak them in Smith's epoxy at least twice. I wouldn't epoxy to the hull, as the washer will be removed when the thru-hull is next replaced. Hopefully after I don't own the boat anymore.
Sailing a '74 Challenger 40' Ketch rig out of San Francisco
sfchallenger is offline
post #13 of 18 Old 12-06-2011
mitiempo's Avatar
I partially agree with the above - plywood is better than solid wood. But the backing plate, whatever it is made of, should be on the underside of the deck, not the liner as there is a gap between the liner and the deck. Tightening the bolts will move the liner closer to the deck. I would try to get the backing block right under the deck.
As far as epoxying the backing block to the deck, or the inside of the hull in the case of a through hull, I think it is the best idea as it will become part of the hull or deck, strengthening it a great deal.
For through hull installation, see this link: Replacing Thru-Hulls and Seacocks Photo Gallery by Compass Marine at pbase.com
And fiberglass or G10 is ideal. What I do is save any fiberglass scraps I remove from any boat - mine or others as I work on boats - and cut backers from them for my use. Any boatbuilder should have offcuts as well, probably free for the asking.
Example here
Brian
mitiempo is online now
post #14 of 18 Old 12-07-2011
McMaster Carr sells a 12"x 12" 3/4" thick fiberglass sheet for $30. I just used it for my backing plates. So far worked great. Search GPO3 for the part.
jacob30 is offline
post #15 of 18 Old 12-07-2011
Maine Sail's Avatar
Any of the HDPE products lack the stability to prevent flex and properly "back", unless VERY thick. The ability for anything, even 5200, to stick to them for long is what really makes them a poor choice though..
I had a customer use 3/4" HDPE for backing plates, Sea Board (same as Starboard) and in one season 3 out of 7 were known to be leaking. They provided no support and the flexing when turning the handles cause the seal to leak.
A small batch of boat builders tried this over the years, mostly small power boat builders, and I suspect also ran into problems. At the last boat show I did not see any of them using it for backing blocks any more, even ones I'd recalled seeing in the past... HDPE is very flexible and you might as well be trying to bed a Teflon frying pan, sealant wise... Nothing really stocks to it...
Leave the cutting boards in the galley and use known time tested and proven methods below water to keep your boat from sinking or leaking...
Of course you don't need to take my advice here's what the manufacturer says:
"King StarBoard®, King StarBoard® ST, King ColorCore®, King ColorBoard® and King CuttingBoard® can not be glued using standard adhesives. Products like 3M’s 5200 work well as a water sealing caulk but will not adhere King StarBoard® to itself or other materials in a permanent bond."
______
-Maine Sail / CS-36T
Maine Sail is offline
post #16 of 18 Old 12-07-2011
Maine Member
BELLATRIX1965's Avatar
Can anybody recommend a good source for G10 plate? Preferably about 5/8" thick, and maybe about 12" by 12" size? Just need a backing plate for an anchor windlass - not a full sheet of the stuff!
BELLATRIX1965 is offline
post #17 of 18 Old 12-07-2011
Maine Sail's Avatar
McMaster Carr has smaller sheets and does stock 5/8".. Don't know about 12X12, pretty sure they do offer it, but I have bought 12X24 a number of times..
______
post #18 of 18 Old 12-08-2011
pdqaltair's Avatar
What is the basis for the thickness? If it is stiffer an stronger than the deck layup, it is wasted. Given the limits of the windlass, deck, and chain, I seriously doubt anything over 1/4-inch will have value to you, but some simple engineering calculations would tell. Additionally, bonding it to the deck will greatly decrease the required thickness, as the deck and plate will act as a unit. If the plate doesn't conform to the curve of deck, the load distribution is haphazard.
Really, the load on the windlass should not be great if a proper chain stopper is used. That is where the big snatch loads are.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
Would A Hardwood Be An Acceptable Backing Plate Baysailor34 General Discussion (sailing related) 22 05-22-2011 12:58 AM
Backing plate weephee General Discussion (sailing related) 4 05-17-2010 10:17 AM
Backing plate options WesterlyPageant Gear & Maintenance 6 09-16-2009 04:22 PM
Backing Plate Size? WhatTheFoley Gear & Maintenance 34 07-22-2009 12:01 PM
To backing-plate or not, that is the question brak Gear & Maintenance 5 07-09-2007 08:13 PM
