-   -   HP Motor Requirements (http://www.sailnet.com/forums/gear-maintenance/7349-hp-motor-requirements.html)
natejount 06-30-2003 10:50 AM
I bought my Kells 23 with a 15HP evinrude OB motor (obviously alot more than I need). I don''t know the exact weight, but I know the boat is heavier than your average 23 footer. Anyway, the motor has **** the bed, back to that later. More immediately, I have a 2HP motor for my dinghy, and I need to know what you guys think about moving my boat with that small of a motor.
Will it work? Will I kill the motor in the short term? Will I float directly into another boat? I only need it to get less than 100yds from where I''m moored.
The 15HP evinrude OB, which is about 25 yrs old, worked fine last week. It starts up fine in neutral, and sounds fine going into gear. The problem is the boat moves less than 5yds a minute, no matter how much it''s reved. There is no discernable difference between how it sounds/starts up now compared to then. I have not checked the rotor, I''m swimming under today to check it out while it''s still in the water...Hopefully there''s just fishin'' line or something twisted around it...but if not, what could be the culprit?
Sailmc 06-30-2003 11:16 AM
Make sure your prop is still there. Make sure it''s not stripped. If you have no wind or current the 2HP will move your boat but I wouldn''t like to do it. There''s always wind or current.
jparker11 06-30-2003 11:33 AM
With engine not running, put it gear and try to rotate the prop.
Don''t know if Evinrudes have shear keys or rubber bushings, but it sounds awefully suspicious.
Next thing to check might be a bad case of barnicles.
Silmaril 06-30-2003 11:39 AM
It may be a shear-pin in your prop that has, well, sheared! It is the connection of choice years ago between the prop and the drive. If your prop hit anything, or became entangled, the shear-pin was "sacrificed" in order to prevent more costly damage to the motor. Problem was, those damn shear-pins always seemed to let lose for no appearant reason. I recall that our club had a whaler with a 25hp "John-rude" OB that went through a pin a week!
Easy fix though. Pull the prop, drive out the remains of the old pin and install a new one.
Your engine is probably turning the prop through friction just enough to make it seem like its working, but won''t put any torque to the water.
natejount 07-01-2003 04:36 AM
OK, so I jumped in the water, and put it in gear, and it did not spin freely. it went about 1/2 turn each way very freely, and after that it gave some tension but was still easy to rotate, but definitely didn''t spin. Now what? I took it out of the water and I''m going to mount it in a trash can and see what I can see.
cyberlord 07-01-2003 05:21 AM
Sounds like you have the rubber friction type, but it could be that the shear pin is lodged somewhere causing just enough resistance.
I''d say you have the rubber friction type and they need to be replaced.
I''ve always had shear pins in any OB I''ve operated, so I can''t be of much help in fixing/replacing.
Good Luck,
Tim
KenD 07-07-2003 09:30 AM
Bite the bullet take the thing to a pier an pull the motor then look take the prop off shear pins cost about 50 cents each not a high price to get going again. Don''t know much about the bushing type but with luck the shearpin type will take less time to fix then to read this,besides I hate treading water and or standing in a foot of goo while working on a motor. good luck
hamiam 07-08-2003 10:42 AM
Bite the bullet and bring the ******* thing to an outboard mechanic. While I agree with the above posts regarding the shear pins, it could be a problem anywhere along the drive train. I would not risk burning out my 2hp motor or my boat for something that can probably be fixed for $100.
pirateofcapeann 07-10-2003 08:13 PM
I ran all around New England waters for 5 years pushing my Columbia 22 with a 1.2 HP British Seagull. She was a heavy barge as I lived aboard, year round and carried all of the things I needed to make it do-able. I got 3 1/2 knots average out of her. Yes, without a doubt you can push your Kells around with a 2 HP but don''t expect her to come out of the hole like a dragster. You''re not going to hurt it any, it''s only going to push just a certain amount and that''s it. Planning is the key to working around with low HP. As for the big motor, it sounds like the prop has let go from its bushing, in which case, you may need a new prop. Or if it has one, the shear pin has let go.
KenD 07-16-2003 09:28 AM
Hamiam
Profanity is the way for an immature mind to express itself forcefully. That gotten out of the way I do concur with your basic premise,that the problem could be anywhere in the drive line,I''m just suggesting that they would check the inexpensive things before calling in the big guns.
