Engine Driven Bilge Pump - Page 2 - SailNet Community
post #11 of 14 Old 04-11-2011
Originally Posted by Barquito View Post
I think what you need is a dedicated motor with a supercharger and fueled by nitro-methane
I think that sounds like a reasonable layer of security, especially if you can use it for other purposes (firefighting, washing dishes...)
wet T-Shirt contest.....
neoxaero is offline
post #12 of 14 Old 04-11-2011
EJO
Dutchman
EJO's Avatar
The "T" set up Denise mentioned is your most economical and least space taking option. I've done this in all my previous wooden boats and a 3-way valve keeps both engine cool and bilge empty. That option with 2 electrical bilge-pumps should give you enough time to get of the boat in your life-raft B-4 debris starts plugging it up. You can get a nice cast-bronze strainer to buy some more time.
Hence my undertone in the above, your (OP) proposed set-up is overkill, especially for a small boat like yours. What a waste of resources and did you consider the HP that set-up requires?
Skipper E-J
S/V "Sailmates" 1973 IRWIN 32 Classic
I want to live and sail forever, so far so good[/SIGPIC]
EJO is offline
post #13 of 14 Old 04-11-2011
CapitainMike's Avatar
I think an extra special size ClamSeal is called for then he can block the hole and won't need a pump.
Capitain Mike
Mediterranean Sea
Cobra 850
1978
8.68m
"Money won't buy you happiness but it will allow you to buy a yacht big enough to pull up along side it"
"Please God be kind to me your sea is so wide and my boat is so small"
CapitainMike is offline
post #14 of 14 Old 06-27-2012
Red face Re: Engine Driven Bilge Pump
I have a vision of a pulse jet with the pressure waves providing the pumping action. Home made jet & pulsejet engine
Iolanthesf is offline
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 12:36 PM
Refrigeration - Engine Driven or DC Compressor? matt2 Gear & Maintenance 28 03-11-2009 01:10 PM
mount for engine driven compressor on 4JH-TE TradewindSailing Gear & Maintenance 1 12-06-2007 12:33 PM
Engine-driven refrigerator/freezer poopdeckpappy General Discussion (sailing related) 6 05-30-2007 01:22 AM
ENGINE driven Watermaker tjkassen Gear & Maintenance 2 02-07-2005 02:03 PM
