Old 04-10-2011
johnnyandjebus's Avatar
johnnyandjebus is on a distinguished road
90 Degree Coaxial Connector?
Hello all
I am in the process of installing a VHF radio on the boat. The antenna is installed and the cable has been run down the mast. While i have not yet looked or measured I suspect that I may have a problem with space relative to installing the radio, in particular enough space behind the radio to screw in the cable with out a tight bend.
Does any one know where to find a high quality 90 degree coaxial connector?
Is using one a good/bad idea?
Thoughts?
Thanks,
John
Old 04-10-2011
kd3pc's Avatar
kd3pc is on a distinguished road
Piece of cake....
http://www.nm3e.com/images/Z-UHF90.jpg
they make 90 degree adapters and they are low loss for the most part. Get a name brand, silver plate or one that says AMP on it.
You may be able to get them locally at a truck stop .
best of luck
Old 04-10-2011
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
John
If you can't find it locally, here is where I would get it (not because others are not good, just because I am a HAM operator and I am familiar with this chain)
Ham Radio Outlet
UHF-15, UHF RIGHT-ANGLE CONNECTOR
Specific item
Rik
Irwin Citation 34
snapped coaxial cable for SSB yzlian Gear & Maintenance 13 03-09-2011 01:15 PM
New Diesel Tank -- 90 degree bend sailingharry Diesel Engine Forum 6 04-07-2010 09:09 PM
When do you use the 225 degree masthead light? EO32 Gear & Maintenance 21 05-18-2009 10:55 AM
20 degree engine start hertfordnc General Discussion (sailing related) 6 01-17-2009 02:58 AM
through deck coaxial cable-what wonderful suprises await me, my deck and my drill? bwu Catalina 1 11-20-2006 01:06 PM
