Old 04-10-2011
Incantation is on a distinguished road
johnson 3.3hp outboard 2-stroke q's
Hi there,
Was helping a friend for a few mins with a johnson 3.3hp 2-stroke he bought from a consignment store. He has no idea what its history is.. but the motor was manufactured 11/98, and while the cover looks faded.. the motor itself looks pretty good.
I've read these are re-badged tohatsu motors and that they are very reliable..
Anyway, we troubleshoot(ed) as follows:
- check fuel lines
- new fuel and oil 50:1
- new spark plug
- new ignition wire
- checked for spark.. OK
- compression check.. OK
The kill switch is broken.. so we clipped the two wires running then and stripped them to expose the wire. I suspect that connecting the wires would short the motor and kill it.. but we tried starting the motor with the wires in both connected and disconnected configurations.. nothing
It has just the forward gear and the prop spun freely when pulling the cord.. it wouldn't fire though..
I don't really know what else to suggest.. or try. If anyone could suggest the next few steps I would appreciate it. I suspect it must be the carb.. but confirmation from someone who knows the motor and/or outboard in general would be appreciated!
Thank you
Old 04-10-2011
CapnRon47 is on a distinguished road
Johnson outboard
I also have a small Johnson (err, that doesn't sound right!) outboard that I purchased from a consignment store. Remember there is choke that needs to be pulled out to start and then pushed in once it catches. We had to completely overhaul the carb, it was all gunked up. Also cleaned the needle valve, replaced the spark plug and used new gas with the right oil mixture. It purrs like a kitten now and runs fine.
cheers,
Old 04-10-2011
PaulfromNWOnt's Avatar
PaulfromNWOnt is on a distinguished road
Get yourself a spray bottle, and spray some fuel/oil mix directly into the carb and see if she'll fire. If you get her to sputter, then it's the carb that likely needs a good cleaning. If you get nothing, then it'll be another issue (but you say you have spark, so she should burp.
Old 04-11-2011
tommays's Avatar
I would take out the sparkplug and ground it on the block and see if you have spark
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 04-11-2011
JimsCAL's Avatar
JimsCAL is on a distinguished road
Carburetor may be gummed up from sitting. If it starts briefly with a shot of starting fluid in the intake, that would confirm its a fuel issue. If so, a carb rebuild (or a new one) may be in order.
Old 04-11-2011
yea i have the carb sitting in cleaner now.. i don't see what else it could be. think i will buy a rebuild kit for it tomorrow and hopefully that will solve the problem!
Old 04-12-2011
delite is on a distinguished road
I believe Mariner, Nissan and Tohatsu are the same engines toady. Johnson has been made by a few companies over the years but I dont know who made them in '98.
Old 04-12-2011
When you strip down the carb pay close attention to the jets and orifices. On the small engines I believe there's an orifice hidden under what looks like a rubber plug. Any crud in these and you're pretty well toast.
They are easy to miss.
1984 Fast/Nicholson 345
Old 04-12-2011
^ thanks man.
delite from what i've been told that particular vintage was made by tohatsu..
Old 04-16-2011
Ok so i cleaned the carb.. soaked it in cleaner, inspected and it's all clean.. no varnish or anything.
And it STILL won't start! But after pulling say 100 times on the starter cord, fuel started dripping out of the exhaust and it was brown in colour. Not sure what this means.. perhaps the colour comes from the inside of the exhaust channel..
Stumped now.. :/
No Name 2 HP 2 Stroke Outboard eherlihy Gear & Maintenance 17 04-03-2011 08:49 PM
Diesel vs 4 stroke outboard??? bugged Gear & Maintenance 21 11-28-2010 06:15 PM
6 vs 8 hp four stroke outboard slimpicknns Introduce Yourself 3 06-27-2009 06:50 PM
1990 Johnson 3 hp outboard erps Gear & Maintenance 22 05-09-2009 10:21 PM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 05:08 AM
