Old 04-11-2011
Lost at Si!
lostatsi is on a distinguished road
Gel Batteries Vs Sealed Lead acid
I would appreciate some opinions based on ACTUAL experience with house batteries. I have two 8G4D 12 volt Gel batteries on my live aboard under the bed. They are shot and I have looked into replacements. $425 each for the Gel, $300 each for the same in a non gel or Sealed lead acid. I have a Heart interface Link 2000 Monitor-charger.
Are the gel worth the extra money?? If so why. I don't mind spending the extra, I just need some HANDS ON advise and this site has been great in the past.
Old 04-11-2011
n0w0rries's Avatar
n0w0rries is on a distinguished road
I think 6V Golf cart batteries are tough to beat... bang for the buck.
1991 Catalina 34 "Summerwine"
Old 04-11-2011
Lost at Si!
noworries
Not familiar with golf cart batteries. To achieve the same performance as 2 "working" 8G4Ds what should i expect as far as cost and the amount of room I would need to accommodate these puppies.
Old 04-11-2011
n0w0rries's Avatar
Costco 6V Golf Cart batteries are 220Ah and cost $80/ea at my local store.
You wire them in series to get 12V
They might be a little taller then what you have now, but you should be able to fit 2 6V in the same spot as your old battery.
How much are those big batteries? If they're around $600 the 6V solution is about half price. I doubt the AGM batteries would get twice the performance.
Old 04-11-2011
fallard is on a distinguished road
Gel cell batteries can handle a higher charge rate than liquid cell batteries. When you are sailing, will limited charging time, they will do better than liquid cell batteries. If you are primarily on shore power, it may not matter and you might as well go for price.
Old 04-11-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
Go with the 6 volt agm lifelines. Their footprint is much less than most 6 volts, they can even be laid on their sides. They accept a charge faster than gel or wet cell, and I beleive can be deep cycle many more times. You pay a good price for them, but they are worth it. I prefer the 6 volts as they are portable where an 8 d is just too damn heavy.
6 volts are the way to go.
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 04-11-2011
mitiempo's Avatar
I agree the 6 volts are the way to go but there is no evidence that AGM will cycle more than a good flooded golf cart. In many cases they withstand many less cycles. They also will not tolerate not being fully charged regularly. If on shorepower that is not a problem but it can be if cruising long term.
Brian
Old 04-11-2011
shogan50 is on a distinguished road
Not familiar with your charger, but if it doesn't have a desulfator function, you might try one. There is evidence to suggest that I brought my wet cell 6V golf cart batteries back from the brink with Power Pulse desulfator.
Islander 30 MKII "Sojourn"
Old 04-12-2011
Lost at Si!
Shogan50
Charger has equalizing feature, isn't that the same as the desulfator. Are you suggesting I try this on my old batteries? Instructions say it's not normal to do this on gel batteries, but doesn't say DON'T.
Cheftosail
Is lifelines a brand?
All
Will I need a storage tray if I go away from gel? Leaks,fumes? And will I have to get rid of my start battery which is gel if house are non gel?
Old 04-12-2011
No, I don't believe you can equalize gel batteries, but you can desulfate them. I have wet cell house batteries (6V Golf Cart) and an optima red top AGM starting battery, combined with a combiner. Also,(at work, can't look it up right now) either pulsetech or their competitor has a procedure for determining if your batteries are too far gone to save. See FAQ here -> TechTalk FAQ
AGM batteries with Lead Acid Charger jamiemiller Electrical Systems 20 11-04-2010 02:47 PM
Batteries, gel vs lead acid?? sailnovascotia Gear & Maintenance 10 05-14-2009 09:57 PM
Source of sealed batteries ? wind_magic Gear & Maintenance 6 07-22-2007 11:44 AM
Lead acid, agm, or gel batteries? aroundtheworld Gear & Maintenance 5 03-26-2006 07:57 PM
Sealed lead-acid batteries sneuman Gear & Maintenance 4 10-16-2003 09:25 PM
