04-13-2011
Originally Posted by mitchbrown
Hi there Rbarkus
A fresh water flush is a good idea especially when your boat is laid up for a period of time. I just installed 2 such devices on the 80 foot yacht that i work on (on the 20 KW gensets). All that is necessary is to put a Y valve on the inlet side of the strainer basket which is between the thru hull and the basket. then put a hose bib on one side of the y and the other side goes to the basket. All thats necessary is to connect the dock water hose to the hose bib and flip the Y valve turn the water on and start the engine. Always flip the y valve back when disconnecting the hose so the system is ready the next time you start the engine.
Mitch
Be very careful connecting unregulated pressure dock hose. The pressure in such systems can damage the seals in your raw water pump allowing water to get into the engine.
Better to feed the dock hose into a 5 gallon bucket and place a pickup hose into the bucket thus breaking the pressure from the dock hose.
Tim R.
Living aboard in Portland, Maine
1997 Caliber 40LRC
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
