Old 04-12-2011
Lendow's Avatar
Lendow is on a distinguished road
vc17 saltwater
Can a bottom be painted in vc17 and years later panted over with a salt water antifouling . I have a new epoxy bottom on my cc29 I may or maynot sail in salt water years from now can I switch over then or do I need sailt water antifouling now.
Cheers
Old 04-12-2011
BigZ is on a distinguished road
Painting over VC17 with a different paint doesn't work. The VC would need to be removed before applying a different AF. But it's fairly easy to remove, some wet sanding is usually sufficient. If you're in fresh water now I'd just use the VC until you moved to the salt water area.
Old 04-13-2011
Minnewaska will become famous soon enough
Pettit used to have a compatibility chart that suggested some of their paints could go over VC17 with a rough sanding. They've changed that and now, nothing is compatible over VC17. I'm told that VC17 has teflon in it, which is specifically included to keep things from sticking. Copper powder is also added.
I can say from personal experience that after one season with VC17 and about 4 diver hull cleanings, you can see through it when you haul for the winter. Not hard to get back off, keeping it from coming off would be harder.
The only consideration is that when removed down the road, you may be looking at a new barrier coat too. That could be the rub.
Jeanneau 54DS
VC17 in saltwater Minnewaska Gear & Maintenance 6 05-05-2010 09:08 PM
VC17 or micron petrus45 Gear & Maintenance 4 05-21-2008 11:50 PM
Another VC17 Question sailortjk1 Gear & Maintenance 4 03-27-2008 03:30 PM
Interlux VC17 removal TradewindSailing Gear & Maintenance 6 12-09-2007 03:08 PM
vc17 apply ..when??? thorJ30 Gear & Maintenance 3 11-10-2004 07:53 PM
