04-13-2011
if you use crimp rings, get the good stuff, else the cheap ones will corrode away in no time. Also if you use the rings, make sure that you have some "shark bite" connectors of the proper size, just in case you have to make a repair and the tools are not available.
I have seen rings, shark bite as well as the marine versions of both and all seem to be far better than the gray stuff or vinyl and hose clamps.
I use red and blue colored PEX so there is never confusion as to which is hot and cold. I then use tape to mark the supply side and make a map of where the PEX runs.
All the best in your refit
