  #11 (permalink)
Old 07-05-2003
fer@fer's Avatar
fer@fer is on a distinguished road
Lifelines - need help
Hi Knothead,
I am not keen at dacron lifeline as a coleague presents (The Novel idea a couple of threads up), due to the fact of UV power potential in deterirating the line, plus the chafe factor over the lines, plus the elasticity issu of dacron. Advantage of this kind of dacron configuration could be that you are obliged to change your lifeline every 6 months.
However spectra lifelines will cover the elasticity issue. How can you cope with UV issue as well as the chafe factor?
Regards & happy splices
Fernando
  #12 (permalink)
Old 07-07-2003
knothead's Avatar
There is always the option of using those plastic shroud covers. I would sure rather see those things used on synthetic lifelines than on wire shrouds. But with those and a little rigging tape one could protect the lifelines from chafe and uv as well as increasing the diameter to make them more comfortable.
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
Lifelines Trami Gear & Maintenance 16 01-05-2004 05:01 PM
Lifelines wgfischer Gear & Maintenance 8 06-17-2003 11:39 AM
Lifelines catnip508 Gear & Maintenance 1 06-01-2002 10:03 PM
Spectra Lifelines? rrobar Gear & Maintenance 5 03-01-2002 07:17 AM
