04-13-2011
Pearson 303
If it is between the seacock and pump, you run the risk of the pump pulling air in through the vent when you are trying to pump water. If it is between the pump and bowl, this won't happen. Raritan addresses this in their install manuals (available online). The vent should have a one way valve in it so that it only allows air in, but will not allow water out, so no worries about water being pushed out the vent. Hope this helps.
