04-13-2011
k-cups don't seem like a good concept for the boat. The used and unused cups will take up a lot of space compared to other methods.
Also, the keurig machine or standard coffee maker take a lot of power for a boat that is not attached to shore power. That could be a real drain on your batteries.
For the french press, if we are in port, we can boil water in the microwave. The propane stove can work for at anchor or underway. There are also smaller units that are specifically made for use underway that run on the green propane canisters that can boil water.
Some thing like a keurig that runs on propane canisters and uses mesh, reusable filter might find a good market on sailboats.
“Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.” -Mark Twain
